Author Topic: M42/M50Turbo Manifold Q's  (Read 3165 times)
RIPDOTCOM
« on: December 20, 2007, 07:28:28 AM »
I have seen that there is a posibility that a M50 Tuebo Manifold will fit the M42 by cutting off runners 1 and 2 and welding the turn on #4 shut. Just want to confirm if this is true or not. Also, does it have to be re drilled? and will a standard 60 trim T3 fit with internal wastegate? I have a 91 318IS that is ready to roll and I want to make that puppy scream.
AL GReeNeRy
« Reply #1 on: December 21, 2007, 11:48:46 PM »
Quote from: RIPDOTCOM;39798
check out 666fabrication.com they got turbo manifolds for m42s. it would save you tha hassle of doin all that with an m50 manifold although its a bit pricey
1991 318is : brilliantrot
nuvolarossa
« Reply #2 on: December 22, 2007, 12:45:05 AM »
there is neukin.com too, I think it's priced right, cheaper than 666fab...
the manifold from 6 cyl that you want to use surely is that from SS autocrap... it's too thin and it will crack. But if you search in this forum there are other 2 men doing what you want :)
