thermostat gasket
Author Topic: thermostat gasket  (Read 2519 times)
PaulC
thermostat gasket
« on: December 17, 2007, 05:54:03 PM »
Is the flat gasket between the connection flange and thermostat (#8 in the diagram below) OK by itself in there or should I use a little sealant?
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_0559&hg=11&fg=35
Any other tips are much appreciated.
Thanks
Paul
'91 318is
sumyungguy
  • b.wood
    • http://www.shutterflick.com
thermostat gasket
« Reply #1 on: December 17, 2007, 06:07:54 PM »
I put some Hondabond on both sides of the gasket just to be extra sealed.
Here is the dilemma I went through.
brad™
thermostat gasket
« Reply #2 on: December 17, 2007, 06:21:16 PM »
I've always used O-ring #7 also. I'm a believer in Hylomar and Antisieze. It's available at:http://cgi.ebay.com/ebaymotors/Hylomar-Universal-Blue-Racing-Formula-35-ml_W0QQcmdZViewItemQQcategoryZ107066QQihZ001QQitemZ110164847315
It's amazing, seals great, and cleans up with acetone.
« Last Edit: December 17, 2007, 06:24:42 PM by D. Clay »
haledj
thermostat gasket
« Reply #3 on: December 17, 2007, 06:25:15 PM »
You can put sealant around the outside, but don't put it on the middle strip.  Air needs to get through that tiny little passage to bleed the system easily.
PaulC
thermostat gasket
« Reply #4 on: December 17, 2007, 06:41:50 PM »
Thanks very much. I got a new o-ring (#7) along w/ a new 88deg thermostat. The new gasket I have has a thin bead (about 1mm) on the inside already. I haven't removed the connection flange yet, but I remember reading in another post about the bleeder passage, which I'm guessing is what the notch cut out of the inner ring of the gasket is for(?).
