Author Topic: Cam locking tool Template  (Read 7670 times)
DaveM-sport
« on: December 14, 2007, 09:29:37 AM »
Thought this might be handy for people. Was posted up on the E30zone
« Reply #1 on: December 14, 2007, 04:04:54 PM »
woah, that's good to know. Wish I'd seen that before I put it all back together ;)
bmwpower
« Reply #2 on: January 15, 2008, 11:05:40 PM »
I'm assuming those are in mm?
rhogg
« Reply #3 on: January 16, 2008, 12:09:46 AM »
Thank you this is my next job!
haledj
« Reply #4 on: January 16, 2008, 02:10:42 AM »
I could mill a few of these out if there would be interest
cheesebox
« Reply #5 on: January 16, 2008, 03:21:41 AM »
If you're going to make this tool, I'd advise the following:
1. Take your own measurements of your camshaft ends using a vernier caliper - preferably before you remove the chain and sprockets. The pic above was published in the Haynes manual, and the dimensions aren't that accurate. If you add up all the widths along the bottom of the diagram, it totals 241mm, not 240mm as it shows at the top of the pic.
2. Use steel plate, min 2mm thickness. Otherwise you'll have trouble keeping the tool in place, due to the camshafts trying to rotate under the force of the valve springs.
« Reply #6 on: January 16, 2008, 08:13:58 AM »
Quote from: cheesebox;41298
Quote from: haledj;41296
If you take all of the above into account, I'm interested.
bmwpower
« Reply #7 on: January 16, 2008, 02:29:21 PM »
Just make it adjustable like the factory tool, but that would be more work.
If your're gonna do it, do it soon... I need it ASAP :)
dave45056
« Reply #8 on: June 12, 2008, 12:00:50 PM »
Check out this link... everything you need
http://www.318ti.org/forum/showthread.php?t=11334
