... since I started this post and I hope you guys are still out there as I am finally am getting around to doing this build.
Couple of updates on me and how this thing is going together:
I have now built and set up a few different engine management systems for a few cars including a Megasquirt for an M20 stroker. I did the whole thing from scratch and though it took a while, I did learn a lot. One of things I've learned is that I would pay money for a quality MS timing table to get my tuning going. Fuel tuning is a piece of cake if you know where you want your AFR, but the timing is still a mystery to me.
So if anyone has a boost timing table or more specifically, one running a DASC, I would be stoked. I know that would not be a turnkey thing for me, but a good starting point is key.
All that said, here is the set up I am going to run (I call it an M43
- M44 motor (head, pistons, rods - all stock)
- M42 Crank
- Compression Ratio should be around 9.3:1
- Boost Target = 12psi (stock 5.75" crank wheel & 3.4" pulley)
- M42 front cases, cam sensor, 60-2 crank sensor, throttle body & TPS
- M44 knock sensors
- Megasquirt (fuel & spark) running off of MAP with 42# Hi-Z injectors, full length headers, & 3" exhaust
Where, oh where do I begin with timing. I DO NOT feel comfortable with even trying to start the car off of one of the MS generated maps. No way.
I have started a series of posts below that outline the basics of setting up the file. Most of this is based on what I just did for an M20 motor, but it is all subject to review by others and I haven't (REPEAT - HAVE NOT) run a motor on this file yet, so please don't take any of this as a sure thing just yet.
J.
