Author Topic: Bimmerworld control arm deal??????  (Read 2721 times)
longms
« on: November 30, 2007, 01:18:14 PM »
More noob questions from this guy in the suspension forum...
My ball joints are shot and I will be doing a lot of upgrades on my M42 is. I am looking at the control arm kit offered by bimmerworld. It is the kit seen on the main page that has steel ball joint with powerflex control arm bushing for $199.99.
1) Does this fit our cars?, 2) Is this one control arm or is it a "kit" with 2?, and 3) if installing HR sport/Bilstein sport suspension setup, do i need to get the off-set control arm bushing?
I have already bought the bushing but I ordered the centered one. Do I need to have the off-set to better pair up with my new suspension set up? I have done polyurethane in the rear as well.
Thanks guys
robweenerpi
« Reply #1 on: December 18, 2007, 07:05:15 PM »
E30 Version will fit fine.  E36 will too really.  Offset is the way to go if you want good handling.
« Reply #2 on: December 19, 2007, 02:43:04 PM »
Offset just increases the caster. This means the farther you turn the steering wheel, the more effective camber the front wheels will have. Offset ones will reduce turn-in but reduce understeer/scrubbing in tight corners and dramatically improve stability.
