Author Topic: Startup whine  (Read 2904 times)
m42mccabe
Startup whine
« on: November 28, 2007, 02:32:40 PM »
On cold starts I've been noticing a high pitched whine for a few seconds or so. It goes away immediately and I can't hear anything wierd going on when I'm driving. As it's been getting colder the noise lasts longer (5-7sec) but it still goes right away. I'm using Delo 400 15w-40 because my timing chain is fairly worn and I need good lubrication, could that be the cause?
Any ideas would be great.
318kid
Startup whine
« Reply #1 on: November 28, 2007, 06:40:32 PM »
I dont know whats is wrong but mine makes the same noise. Any help would be great for us.
Jimmy Lewis
Startup whine
« Reply #2 on: November 28, 2007, 08:16:57 PM »
Have you replaced the tensioner? If you haven't pulled your lower pan in a while that probably wouldn't be a bad idea. My car sounded like a lawn mower running on diesel before I replaced my tensioner. That of course was in the summer months, I'm not too keen on the climate in Oregon during November. I ran pretty thick oil in the warm weather, I'm not sure of the implications of running thicker oil in the winter; maybe it is playing a role in your noise.
1999 Estoril M3
1991 Brilliantrot 318iS
(for sale)
teamgtnfx01
Startup whine
« Reply #3 on: November 28, 2007, 11:14:59 PM »
could it be the bendix in the starter
1992 318 vert with 66k
m42mccabe
Startup whine
« Reply #4 on: November 29, 2007, 12:16:01 AM »
Quote from: teamgtnfx01;38554
Is there a way to tell?
How easy is it to fix?
2002maniac
Startup whine
« Reply #5 on: November 29, 2007, 10:58:37 AM »
It could be a slipping accessory belt.  I always have to tighten my belt when it starts to get colder.
Of course a slipping belt would be more of a squeal than a whine, but onomatopoeia isnt the greatest form of diagnosis. :p
JHZR2
Startup whine
« Reply #6 on: December 17, 2007, 10:06:21 AM »
a growl at first startup, quieting within 1-2 seconds is the tensioner pressurizing.  A speed related tick would be the lifters.  A tick that gets louder with engine temperature is the injectors.
A whine that is just at the very start, from what Ive seen, is a slightly incorrect adjustment or wetness on the accessory belts.  The alternator is heavily loaded after sitting in the colkd and then doing a cold start... so its putting a lot out.  If the belts are glazed, loose/tight, etc., they will whine a bit.
Check your belts
JMH
