Is there a trick to removing the plastic coolant pipe out of the block (under the intake)? I tried a search and found lots of great info, but still am not sure about this pipe. Most of the coolant and vacuum hoses need to be replaced and from what I've read this piece can also crack with age. Is there a seal?
TIA
Paul
(btw, the car has 88k mi and I've only had it 2 weeks)
