Author Topic: Timing Chain & Crank Sprocket  (Read 3211 times)
nicknikolovski
« on: November 18, 2007, 03:46:35 AM »
Hi guys, i'm gonna replace my chain, the rails, and sprockets as well as the gaskets.
1. Anyone know much about the crank sprocket for the M42? What I want to is does it simply slide onto the crank and get bolted back on or does it have to be heated to a certain temp before going back on like the M10 crank?
2. Also if I do the timing chain and unbolt the upper & lower timing cases obviously, do I need to replace the "dreaded" profile gasket in the upper case?
3. Is it possible to replace the gasket without removing the cylinder head?
Any help would be largely appreciated.
Thanks
cecotto
    • http://www.cecotto.dk
« Reply #1 on: November 18, 2007, 10:47:54 AM »
Quote from: nicknikolovski;37865
Thanks
1. It just slides on there. (Installation: Torque to 300Nm)
2. I'd say if you only do the covers, and don't uninstall the cylinder head, you do not need to do the profile gasket.
3. The profile gasket can only be replaced by removing the cylinder head.
Hope to help.
Steffen Otto Jensen
E30 318is
E30 M3
sheepdog
  • Site Admin
« Reply #2 on: November 18, 2007, 11:11:10 AM »
Quote from: cecotto;37870
Hope to help.
Correct, the real bitch comes from the timing chain housing. Which means messing with the profile gasket and either dropping the lower pan or pulling the head.
Yes, you can do the profile without pulling the head, at least 2 people on here have done it.
« Reply #3 on: November 18, 2007, 12:10:00 PM »
The special tool looks like a piece of sheet metal with a handle.
m42mccabe
« Reply #4 on: November 18, 2007, 10:08:36 PM »
Here's a pretty good site for timing chain procedure.
http://www.esatclear.ie/~bpurcell/318istimingchain.html
You shouldn't have to replace the profile gasket if it has already been done to the car once.
Crank pulley is a bit tough and a camshaft holding tool makes things a bit easier as far a I know.
sheepdog
  • Site Admin
« Reply #5 on: November 19, 2007, 12:49:17 PM »
Quote from: D. Clay;37877
Yup, I used a bunch of feeler gauges, but a cement trowel or thin sheetmetal would work. Only way to go.
nicknikolovski
« Reply #6 on: November 22, 2007, 04:06:58 AM »
Thanks guys, really appreciate all your help and info. I won't need to replace the profile gasket cause I'm only going to remove the timing case covers and not the actual timing chain housing that bolts to the block.
