jester0401
Author Topic: jester0401  (Read 6500 times)
jester0401
jester0401
« on: November 12, 2007, 10:22:18 PM »
Hello every one,
Just picked up a 1991 318is for 2300. I will post pics tomorrow. It’s white with 150k miles, runs pretty well but has a vibration at the steering wheel under 65mph have not figured it out what it would be. Also the temp gauge doesn't work I think its just the thermostat though. Any advice on a car of this mileage  ?
Thanks
Jesse
jester0401
« Reply #1 on: November 12, 2007, 10:24:02 PM »
Well first of, welcome to the site!
With that kind of mileage I would look into fluids, all the rubber bits (bushings) and some general maintenance.
Is it just me, or has there been a recent flood of new 318is owners?!
jpod999
jester0401
« Reply #2 on: November 12, 2007, 11:36:24 PM »
Quote from: dude8383;37570
I think you'd agree with me that that is a very good thing.
Welcome to M42club.  People here are friendly and knowledgable...so don't be afraid to ask questions.
jester0401
jester0401
« Reply #3 on: November 12, 2007, 11:58:17 PM »
Thank guys
Whats a good place to start to get this bmw into tip top shape?
jester0401
« Reply #4 on: November 13, 2007, 02:12:25 AM »
welcome to the site.  Can't wait to see the pics.
Title changed to meet the member rides forum rules...
jester0401
« Reply #5 on: November 13, 2007, 10:39:16 AM »
BMA parts is a great source for OEM parts.
1 - 888 - 262 - 3911
I handle all orders over the phone with Patrick!
jester0401
« Reply #6 on: November 13, 2007, 11:23:12 AM »
Welcome to M42Club! It seems that a lot of 318is's are still around due to their durability. They are being picked by folks like us who see or know the possibility of a car that can be made into something out of almost nothing. They are easy to work on and good to learn on.
Tap on the gauge. If it works, the ground on the back of the cluster is bad and can be cleaned. Then check the sending unit and wire.
First order of business is this download:
http://www.m42club.com/forums/showthread.php?t=964
Second is use the "Search feature of this forum. Even if you don't find what you need, you'll end up learning more about the car.
jester0401
jester0401
« Reply #7 on: November 13, 2007, 03:16:20 PM »
Thanks for the warm welcome every one!
I have decided that the gauge for the temperature is working but that I just need a new thermostat and have purchased it and a water pump cause its down there any way. I have all the gaskets I need I think. 2 for thermostat and 2 for water pump I am also going to change the coolant to BMW blue stuff, it has green in it any other tips on this job?
BMA looks great next time I will buy from there!
Thanks
Jesse
« Last Edit: November 13, 2007, 03:20:12 PM by jester0401 »
jester0401
« Reply #8 on: November 13, 2007, 06:57:24 PM »
For the shudder, that might be worn front control arm bushings. The stock ones in the car a pretty weak, and can be upgraded to offset solid ones in either rubber (oem e30/ 1995 e36 M3) or polyurethane (akg motorsports and others). Non-offset ones are also available.
I think there are a lot more new members. For a long time there was no one new in this section, just updates. In the past few days there have been about 5 new people on here. It's wonderful! ;)
jester0401
jester0401
« Reply #9 on: November 13, 2007, 08:43:02 PM »
worn front control arm bushing? maybe I haven't look under there too hard yet if i was going to upgrade where is a good place to get the part and which one the M3 or the polyurethane?
Thanks
sorry no pics yet tomorrow for sure!
Febi Guibo
  • m42 reporter
jester0401
« Reply #10 on: November 14, 2007, 10:07:36 AM »
hi and welcome... I *highly* recommend the treehouse racing E30 control arm bushing thingies... they are a great upgrade and will (help) put your cars on rails....
Support M42club.com !!
jester0401
jester0401
« Reply #11 on: November 14, 2007, 01:24:33 PM »
Pictures don't want to upload I will figure it out.
jester0401
Need help!
« Reply #12 on: November 20, 2007, 08:10:49 PM »
I have taken the instrument cluster out and there is no bulb/ bulb holder in the check engine slot and others. I am going to try to buy the part but I would think the local auto parts store wont have it and I would really like to get it done so I can drive the car! The car will not smog tell I get this fixed! Help please on if this is normal or I just need a new bulb and bulb housing. Also the water pump/thermostat job went well and I have ordered a timing chain tensioner.
jester0401
jester0401
« Reply #13 on: November 20, 2007, 08:44:44 PM »
see the check engine bulb mount above the female yellow connector  in this picture there is one, on my cluster there is nonehttp://www.auctiva.com/hostedimages/showimage.aspx?gid=20415&image=85255249&images=85255057,85255249&formats=0,0&format=0
Febi Guibo
  • m42 reporter
jester0401
« Reply #14 on: November 20, 2007, 10:57:21 PM »
bav auto has the bulbs and bulb holder... or, PM me your mailing addy, I can send you some.
I'm guessing you might also have an issue that the previous owner removed the bulb to ignore... my initial guess: O2 sensor...
