Author Topic: Ignore if you wish: mess under manifold  (Read 3233 times)
strad
« on: November 12, 2007, 08:29:54 PM »
Yayyy!!  Found my coolant leak, and a few other things lol!  For several weeks have been gathering parts to replace all the rubber hoses under the manifold.  The last one finally arrived today, so set to work.  Ever since I got the car I've been adding a couple ounces of coolant every couple or three weeks.
I'm relieved to discover ample evidence of a leak from the head-heater core hose junction (and a split starting in that hose).  I also found several loose coolant and air hose clamps elsewhere under the manifold-- the result of idiot mechanics or hose shrinkage with age -- I don't know.  This poor car has been neglected -- the coolant that came out was very dirty, and when I took the drain bolt out of the block, nothing came out (?)  So I stuck a coat hanger in the hole and wrangled it around until I got a gusher lol.
So the moral of my story is, if you haven't been under the manifold yet, and you don't have records to prove that someone else has, get under there now, before you blow a hose and overheat the motor!  I got mine in time. . .
Edit: looking down into the cylinders, can still see the cross-hatching: pretty good for 197k miles.
« Last Edit: November 13, 2007, 01:09:21 AM by strad »
dlmrun2002
I agree
« Reply #1 on: November 13, 2007, 10:01:24 PM »
After rebuilding my motor  I  replaced  every coolant and  vacum hose.. PAin in the  butt  but good to know I'm set for the next  bunch of years.
DLM
strad
« Reply #2 on: November 13, 2007, 11:29:06 PM »
The plastic coolant pipe broke in two places while I was removing it from the car -- good thing I had a replacement ready!
Now if I could just get some relief from this other problem. . .
http://www.m42club.com/forums/showthread.php?t=4181
nev parker
pipe in head
« Reply #3 on: November 14, 2007, 08:21:13 PM »
there a small about 3/8" pipe  (aluminum?) that comes out of the head, seen with the manifold off, in the centre...
the pipe on my car is in bad shape, corroded, & i will not feel confidnet that hose is gonna stay on until i renew that short pipe.
Anyone done it or know how that short metal pipe comes out?
Can't budge it on either of my 'spare' engines, it may even be steel.
let me know............
thanks,
nev
« Reply #4 on: November 14, 2007, 10:50:55 PM »
Quote from: nev parker;37688
thanks,
nev
Are you talking about the pipe between cyl 2 and 3 with a bolt stuck in it in this picture?
http://img.photobucket.com/albums/v297/gizmo316i/M42/PB200262.jpg
The solution is to block it off.
http://www.m42club.com/forums/showthread.php?t=3621
teamgtnfx01
« Reply #5 on: November 24, 2007, 10:24:36 PM »
Quote from: strad;37633
can u point out wut pipe u are talking about because i just ordered parts so i can do this whole hose repair procedure and im not sure if i ordered that pipe along with my order
1992 318ic 65k
1992 318 vert with 66k
strad
« Reply #6 on: November 24, 2007, 10:41:57 PM »
It exits the block to the rear of the alternator and makes three hose connections: one up to the throttle body heater, one to the expansion tank, and a third to the firewall.
