Author Topic: Long trip preparation:  (Read 4744 times)
strad
« on: November 04, 2007, 05:44:25 PM »
So the M42's going on about a 1500-mile jaunt this Christmas.  As preparation, I'm replacing belts and all hoses, including the mess under the intake.  water pump will be inspected.  It will get an oil change and I will remove the pan (again) to inspect for loose parts.  Filters will be checked or replaced.  It has a fuel pump about 20k miles old--fuel filter is likely the same age.  Timing chain tensioner was replaced about 1k miles ago -- no abnormal noises from the timing chain.  Rear end and trans are both current on fluid maintenance.  Brakes and clutch hydraulics are recently serviced/ not leaking, etc.
Are there any other gotchas I should be checking for.  I'd really prefer not to blow up my motor on the way if at all possible, and of course not to get stranded :)  And in case you're wondering, the M52 is not in the stable yet -- that's one of the reasons for the 1500-mile jaunt, to pick it up.
« Last Edit: November 04, 2007, 05:51:34 PM by strad »
haledj
« Reply #1 on: November 05, 2007, 02:17:12 PM »
check your spare, seems obvious, but its very important.
also a good jack, the e30 one blows, especially on gravel.
take wrenches, sockets, screwdrivers, wd-50, duct tape, coolant & water, oil , ect
strad
« Reply #2 on: November 05, 2007, 03:13:36 PM »
Yup.  Always carry a toolkit on trips -- had to change an AC compressor on our 2000 Mustang on the roadside once, on a road trip!  Damn serpentine system, couldn't isolate the compressor.
Spare is crappy, I'll borrow the one from my cabrio.  Good call on the coolant and oil too -- usually do carry those items but a reminder is always good.
So my car prep looks okay on paper, huh?  Any spare parts/fuses/relays I should bring?
  • -Receive: 5
« Reply #3 on: November 05, 2007, 04:36:13 PM »
Bring ear plugs. The noise level with 4.1 gears can wear you out faster than anything.
strad
« Reply #4 on: November 05, 2007, 05:55:44 PM »
^^^lol.  I think we'll be fighting over who gets more seat time in the M52 coupe on the way back!
I just decided the water pump needs to be replaced as long as I have the cooling system apart -- ordered it and a Wahler 92-degree thermostat.
haledj
« Reply #5 on: November 05, 2007, 08:20:33 PM »
bring a bunch of stand up comedy- awesome on road trips
I sugest
demitri martin
daniel tosh
jim gaffigan
stephan lynch
dane cook
strad
« Reply #6 on: November 06, 2007, 12:44:16 AM »
Lol: missing from this picture is the water pump, thermostat and two small hoses.
It's not often I have this many new parts all waiting for install!
P.S. If I cared about not scratching the paint, I wouldn't have used it as a backdrop.  It's hopefully  getting resprayed this Christmas, with all but the spraying done by me!
« Last Edit: November 06, 2007, 12:48:53 AM by strad »
pwforprez
« Reply #7 on: November 06, 2007, 09:41:50 AM »
thats alot of stuff. where did you get all the bent hoses. i need all that stuff as well. please point me in the right direction
strad
« Reply #8 on: November 06, 2007, 09:49:33 AM »
All but one of the water hoses come from bavauto's hose kit.  I went with them because the package is convenient.
Pelican is where I got the two four-way hoses and the hoses leading to and from the idle valve, as well as all the gaskets, water pump, thermostat and belts.  I got the plastic water pipe from the dealer (it was in stock!).
I should mention that several of the hoses are not necessary if you do what this guy did.
I decided to put it back together the way it came from the factory though.
n2motorsports
« Reply #9 on: November 06, 2007, 10:25:32 AM »
AAA card
strad
« Reply #10 on: January 10, 2008, 05:16:01 PM »
An update: Besides losing a few ounces of coolant, 1500 miles went by without a hitch.  All that maintenance paid off apparently.
« Reply #11 on: January 10, 2008, 05:49:45 PM »
Nice. My dealer also had the plastic pipe in stock. That's good, because mine grenaded not too long ago. Somehow it managed to break off at 3 of the 4 joints...
pbgd3skier
« Reply #12 on: January 10, 2008, 08:56:09 PM »
Amazingly you may have over prepared.
I try not to change too much right before a trip, some examples.  Replaced a hose on a 535.  It looked ratty at the end and I figured it would need it soon anyway.  Filled system went on road trip.  New hose burst in center, leaving me to AAA to the local autozone, and cobble together a hose.  Should have kept that ratty hose, because really it was ratty for the last 30K miles and worked fine.
Had a similar event with a serp belt on a chevy suburban.  A fuel pump in a ford probe, and a water pump in a Datsun.  Maybe I just have bad luck but I come across these lemon parts more often than you could imagine.
My point being, next time you go on a 1500 mile road trip, install these things a few hundred miles in advance of the trip, then if it blows you will be in your neighborhood, and not on the side of a highway.
1991 BMW e30 318i
1980 BMW R80/7
strad
« Reply #13 on: January 10, 2008, 10:22:00 PM »
Actually, I finished most of this about three weeks in advance of my trip, for the exact reasons you specified.  And believe me, all of it was necessary!  Although I had lifetime service records for the car, it was evident that the maintenance items I went after were due or overdue!
