DISCUSSION
Electrical
Amps
Topic: Amps (Read 3587 times)
Vladi
Hero Member
Amps
November 02, 2007, 05:29:01 PM »
I've measured how many amps the car uses with everything off (engine, etc.) and it turned out 0.86A.
Is that normal? Did anyone measure this?
I also measured my VW Golf it read 0.51A so i'm not far by much...
I\'m here to kick ass and chew bubblegum...i\'m all outta gum
http://www.e30.ro
Shocker
Amps
November 02, 2007, 06:00:36 PM »
How did you measure the current? You have to measure it inline (break the circuit and the multimeter will complete it) you can't measure current with one lead on the + and one on the -.
800 milliamps sounds kind of high with the key off IMO
Last Edit: November 02, 2007, 06:03:46 PM by Shocker
Vladi
Hero Member
Amps
November 02, 2007, 06:54:46 PM »
Yes, i took the - off the battery and i connected the multimeter between the battery - and the chassis -.
http://www.e30.ro
christophbmw
Hero Member
Amps
November 03, 2007, 11:23:52 AM »
.04 amps if its more than that then its to high (also, connect it and wait about 15 minutes and then check it, sometimes the ECU will hold voltage in it capasitors made for voltage spike protection).
Vladi
Hero Member
Amps
November 03, 2007, 02:08:47 PM »
Problem solved. Currently reading 0.25A.
http://www.e30.ro
christophbmw
Hero Member
Amps
Reply #5 on:
November 05, 2007, 07:21:26 PM »
Quote from: Vladi;37094
.25A is still kinda high, .25ma is about right for our cars.
Vladi
Hero Member
Amps
Reply #6 on:
November 06, 2007, 03:59:53 PM »
You're right...battery drained again...:mad: Checking again...
http://www.e30.ro
George77
Amps
Reply #7 on:
December 03, 2007, 09:24:45 PM »
Do you have any car alarm??.Might be one of the problems,and even like that 0.25 means 250 mA ,it's an old model?,should be somewhere near 0.10,if not the only thing that could eat some power it's the cd player or the OBD because has a clock.
12PSI of boost on stock engine
DISCUSSION
Electrical
Amps
