Hello All. Bought the car in August 07. Has 180K and about 20K on a top end rebuild. Have put about 5K on it. Car uses 1 quart between changes
So Far:
AC Compressor
All New Belts
Replaced Vacuum hoses under intake
intake gasket
Plugs
Wires
Coil Pack
Voltage Regulator
Toyo Tires
Stocking up on spare parts: another coil pack, alternator, ECU, and various other fuses relays etc.
On The Way:
Tie rod assembly
Front Bumper(getting rid of the crappy look)
Chip.
Planned:
Springs
Shocks
Center Support Bearing
Flex disk
Comments/suggestions are welcome and have a couple of questions
I dont want to lower the car because of the back roads i have to travel on
so am i ok with stock springs? Is there a spring that will retain clearance?
Should i go with Koni or Bilsteins?
Fuses 3 and 18 are blowing. The auxillary fan still works good but my mirrors do not. Where should i start?
My blower motor has quit twice and started back on its own both times
Any ideas?
