Why a MAF? :
- Better throttle response (esp. off-idle and below 3000RPM)
- Nearly eliminates the stumbly idle
- No more bogging-idle when coming off-throttle
- A little power gain (no numbers yet...will be once it is complete)
- Marginally better fuel economy / catalyst lasts longer*
I guess I owe an update.
I am like 70% done with Version 2.0 of this. I am using a Bosch sensor that wil fit the boot and air-box with $7 in rubber/silicone fittings and is better sized for this application. I have all the translation maps done and programmed into the magic box, but there is a similar issue to the one V1.0 had...but it occurs between 2000 & 3000RPM and is a lot worse (to the point that the ECU cuts the injectors). Now, the WBO2 sensor in my car crapped out on me, so that could be contributing to the problem. Once my replacement arrives (hopefully tomorrow), I will see what exactly is going on in there. The problem only persists at near full-throttle when below 3000RPM. Above there, if you floor it, it GOES. The car feels so peppy, I just hope gas never hits $5/gal because I will have to cut back on groceries to buy gas (Ramen is cheap, right?)!
The idle was smoother once again, and power came on stronger and more smoothly in the upper range. There is NO hesitation between 4000 & 4500RPM any more...it is smoother than it was with the AFM. I am really excited about this, and I am sure there are many who are more so than I. Just bear with me on this, I do not want to sell anything until I am confident that I will be dispensing a quality product; a product that I would be happy with if I purchased (and I am one of those customers you hate...I expect perfection).
*When you pounce the throttle, the flapper-door opens rapidly, and overshoots the proper position (it has mass, and carries momentum). For that brief moment the ECU is told there is a LOT more air flowing than there really is, and it will over-inject fuel for that moment. Extremely rich bursts like that foul spark plugs, build carbon deposits and reduce catalyst life.
