Author Topic: It has begun...E36 rack conversion [PICS]  (Read 8246 times)
« Reply #15 on: October 27, 2007, 04:11:50 PM »
Quote from: bmwman91;36710
Well, I purchased the ones for the E36 rack back when I was getting everything.  When I took the used unit apart, there was nothing in there resembling them.  The ones I have are like big washers with a little tab and a semi-circle welded on.  You have any pics of what I am supposed do to with these?
You know, they may be the locks.
I'll try to get under the car and snap some pics for ya.
« Reply #16 on: October 27, 2007, 04:21:53 PM »
Again, for reference, there are no lock plates listed in the BOM on RealOEM for this rack.  The other E36 cars have them listed, but not the 1.9L Z3.  I have a hard time believing that there is no securing plate when every other BMW has them!
« Reply #17 on: October 27, 2007, 05:24:51 PM »
Quote from: bmwman91;36720
Can you show me in the pic?
longms
« Reply #18 on: October 27, 2007, 05:39:30 PM »
Quote from: bmwman91;36612
I use some stuff by 3M, called Undercarriage Paint or something similar.  $8.99 for a large can.
where did you get the paint from? i need to repaint my rocker panels here soon...thank you
« Reply #19 on: October 27, 2007, 10:03:10 PM »
As for the paint, any old car parts store should have it.  Just look for the rubberized undercoat stuff.
As for the lock plates, Stuck cleared that up.  Apparently a number of racks don't use them...Loctite is the solution in this case.
« Reply #20 on: October 28, 2007, 01:04:52 AM »
The E36 rack and short shifter are the two most enjoyable mods I have done so far. They make the car feel a lot newer and much better. The high pressure line is pricey. I got one made at a hydraulic hose shop for $60. They soldered the BMW banjo fitting to their new crimp fittings and hose.
Frankie
« Reply #21 on: October 29, 2007, 04:41:08 AM »
Is it possible to do that the rack-mod to a non-power steering car (e30 318is)?
sheepdog
  • Site Admin
« Reply #22 on: October 29, 2007, 11:42:08 AM »
Quote from: Frankie;36780
No reason you could not have a custom line made to just loop from one outlet to the other. Would work fine this way.
« Reply #23 on: October 29, 2007, 04:07:12 PM »
Non power steering cars require a change to the steering shaft coupler. There is a write up on R3V about it.
« Reply #24 on: October 29, 2007, 04:27:06 PM »
Quote from: bmwman91;36661
Sure thing.  I plan to document the process.
Quote
It would be nice to have photos or a drawing of the modification of plate #6.  I took shaft part #1 out and then removed plate #6. I cut it so that the lower part of the opening for boot #4 was rotated clockwise (looking from the front of the car). I made an aluminum patch for the open area that was left and pop riveted it to #6. It's a lot easier with #6 out of the car. The angle of the pinion housing is different on the newer racks and they move the lower end of shaft #1 toward the center of the car.
« Last Edit: October 29, 2007, 04:29:54 PM by D. Clay »
