Author Topic: Starter doesn't turn on the key  (Read 3625 times)
duffusdipspinner
« on: October 23, 2007, 02:46:33 PM »
Need help guys.
The starter in the 318iS doesn't turn on the key. The ignition lights come on etc.
Got the starter to turn the engine by connecting it up to the battery direct (well actually shorting the 10mm and 13mm connections), so.........
Is there a fusable link in the wiring to the ignition or anywhere else for me to check ?? Maybe a relay ??
Cheers for any help.
Febi Guibo
  • m42 reporter
« Reply #1 on: October 23, 2007, 03:09:30 PM »
The main relay is under the plastic cover running below the windshield in the engine bay.
But strictly speaking, if your battery gets low, the ignition lights will come on but the car won't crank.
Try a battery booster or a jump start first, to rule out the battery.
Support M42club.com !!
Vladi
    • http://www.bmwzone.ro/forum
« Reply #2 on: October 23, 2007, 04:17:08 PM »
Aren't those three relays for the ECU, O2 sensor and fuel pump? The starter doesn't have a relay. :rolleyes:
duffusdipspinner
« Reply #3 on: October 24, 2007, 03:12:35 AM »
The battery is fine. We can get the starter to crank, but not from the ignition key ;)
