I got an extra hazard light switch and put it in a blank spot. From there, I ran 2 wires to the fuel pump power and spliced the switch in. It was inconspicuous, and all I had to do was switch it off and the car would run for maybe 5 seconds before the fuel rail emptied 100%.
If you do the fuse thing, use the lowest rated fuse. You want it to blow quick, not heat up & start a fire. Especially if it is anywhere near the gas tank / pump.
