Author Topic: Brakes!!  (Read 3352 times)
EN318isPDX
Brakes!!
« on: October 19, 2007, 12:33:39 PM »
Ok so the brakes are toast on my M42, i just ordered Brembo Slotted for the front and cross drilled brembos for the rear. I'm cheap so im going to just do caliper rebuilt kits all the way around. I'm going with some HAWK HPS pads. Ok so my question is.. Bavauto has 2 different SS brake lines.. one teflon coated and the other is not.. same price.. so should i order the teflon coated ones?
ducatipaso
Brakes!!
« Reply #1 on: October 19, 2007, 01:03:31 PM »
any reason why slot front drill rear?
EN318isPDX
Brakes!!
« Reply #2 on: October 19, 2007, 01:08:31 PM »
Quote from: ducatipaso;36085
slotted for front because they are vented. want the air ducts to push the dust back and not in. drilled for rear because they are solid.. dont want drilled in front because i do alot of HARD stopping.
ducatipaso
Brakes!!
« Reply #3 on: October 19, 2007, 01:12:12 PM »
interesting. i have the ATE rotors with the wavy slots, dunno how much they do, but I had brembos on my old Golf and they're nice... and in typical VW fashion they're cheaper than OEM. :D
EN318isPDX
Brakes!!
« Reply #4 on: October 19, 2007, 01:19:57 PM »
Quote from: ducatipaso;36089
Vdubs are too cheap.. ya i did some OEM replacements on my last E30 and wasnt really satified with it. I know a couple guys with tuned 325is and they run drilled brembos all the way around for the last year and have not had to change the pads and it still stops like new
silverblades181
Brakes!!
« Reply #5 on: October 19, 2007, 01:20:49 PM »
You might aswell get the teflon coated lines. What brake fluid are you going to use? I'd recommend ATE Superblue DOT 4 if you intend on bringing it to the track.
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
EN318isPDX
Brakes!!
« Reply #6 on: October 19, 2007, 02:00:30 PM »
Quote from: silverblades181;36094
ya figure it cant hurt. as for brake fluid im not really sure yet. i may replace the master cylinder while im doing the job, the car is just my DD dunno if im going to track it quiet yet. still got a few things to work out before its worthy
EN318isPDX
Brakes!!
« Reply #7 on: October 19, 2007, 02:54:14 PM »
So no answer on the Teflon on the lines... Guess it cant hurt may as well get the teflon ones.. guess brake dust wont stick to them haha
Brakes!!
« Reply #8 on: October 19, 2007, 07:21:06 PM »
I actually have zimmerman x-drilled rotors all around. I havn't had any problems with warping, but I don't know how they compare pricewise to the brembos.
vitesse
Brakes!!
« Reply #9 on: October 19, 2007, 08:41:49 PM »
I was told be some of the spec E30 guys, they use to use drilled/slotted rotors on their race cars.  They have found that the drilled/slotted rotors didn't help their braking at all.  So they went back to stock for a much cheaper price.  I know they don't look as cool, but the performance for E30 brakes should be the same either way.
1991 318is: 5 Lug conversion - M brakes - GC track/school 500/650 - (more power here)
