Author Topic: Convince me to go 4cyl  (Read 18816 times)
jpod999
« Reply #60 on: October 20, 2007, 11:00:37 AM »
I don't know how you guys are getting such good gas mileage...I just filled up yesterday, 23mpg.  And I don't leave it at 5,000 RPM all the time.
christophbmw
« Reply #61 on: October 20, 2007, 12:49:13 PM »
Quote from: jpod999;36155
agreed, around town i only get 23ish, on the freeway i can get close to 28 one time i got 29.2, i was stoked i was doing 85mph (on the way to bimmerfest).
eric ^__^
« Reply #62 on: October 20, 2007, 01:55:55 PM »
so the mpg gauge doesn't actually work?
christophbmw
« Reply #63 on: October 20, 2007, 02:21:11 PM »
Quote from: eric ^__^;36172
it does but its not accurate, full throttle shows 3-5mpg while accelerating, neutral shows 60+ mpg while coasting on the freeway and driving 70mph in 5th shows about 26.......if you can calculate all those difference in your head while driving; then ya it works. its more of a sophisticated vacuum gauge if you ask me :rolleyes:.
sheepdog
  • Site Admin
« Reply #64 on: October 20, 2007, 06:51:26 PM »
It works decent if everything is in perfect working order.
When was the last time your fuel filter was changed, oil, plugs, O2 sensor, etc...
Still I find mine to not be bad. As has been said, you have to average it out.
And yes it is pretty much a vacuum gauge with some tweaks to it as far as I can tell.
ducatipaso
« Reply #65 on: October 21, 2007, 10:16:55 PM »
my car only has 135k on if... that might be helping ;)
EN318isPDX
« Reply #66 on: October 22, 2007, 01:03:38 AM »
Quote from: ducatipaso;36253
not bad. have you ever replaced your O2? thats one of my top tune up pieces to come
« Reply #67 on: October 22, 2007, 09:31:54 AM »
I dunno, I'm getting 27 with almost no highway driving. 201k miles, magnaflow exhaust, mark d chip, basic stuff like that, so I doubt that's why. This is calculated with the trip odometer, and I don't know how accurate that is. My overall tire sive is very close to that of stock tires.
ducatipaso
« Reply #68 on: October 22, 2007, 10:59:37 AM »
Quote from: EN318isPDX;36257
No, I have not. The car had 105K on it when we bought it 10 years ago (from a dealer) so I'm sure it had it done as they did a L2 inspection on it before we purchased it.
It does surge quite a bit at idle [esp when cold] so I'm sure a tuneup is in order. I'm thinking I might replace the AFM, plugs, wires and O2 sensor this spring.
« Reply #69 on: October 22, 2007, 03:58:26 PM »
Idle is probably the idle control valve. It is a cylinder behind the upper intake manifold and is partially hidden by the cowl. This is half the cost of a new AFM and is probably more effective. My AFM is original at 200k and has no problems, but the ICV has been replaced.
EN318isPDX
« Reply #70 on: October 22, 2007, 04:11:12 PM »
Quote from: ducatipaso;36287
Nice, my car was bought used and it was "inspected" during this inspection they must have removed my oil sump pickup haha
ducatipaso
« Reply #71 on: October 23, 2007, 08:06:12 PM »
Quote from: gearheadE30;36314
cool I'll check into that. it goes rrrrrRRRRRRrrrrrRRRRRRRrrrrrr when it's cold.
jpod999
« Reply #72 on: October 23, 2007, 08:43:09 PM »
Quote from: ducatipaso;36428
Very technical.  ;)
ducatipaso
« Reply #73 on: October 24, 2007, 11:06:19 AM »
Quote from: jpod999;36432
Very technical.  ;)
sometimes, a sound is worth a thousand written words :D
the amplitude of the idle hunting is from about 650-1100RPM
the frequency is about 1Hz
better?
