prepping for track day
Author Topic: prepping for track day  (Read 3321 times)
gwb72tii
« on: October 12, 2007, 02:25:01 PM »
My son (325i) and I (318is) are going to a driving school/track day at the end of the month. Here's what we're doing to prep, and I appreciate any suggestions about anything else we should do;
325i
replace brake pads (pagid)
flush/replace brake fluid
the timing belt was replaced about 15k miles ago
check dif fluid level (LSD 4.10)
change oil
adjust tire pressure
318is
drop oil pan and inspect (just read about loose/missing bolts. yikes!)
replace brake pads (mintex red)
replace timing chain tensioner with new one
change oil
the 325i has eibach springs/bilstein sport shox
the 318is has H&R springs/sport shox
missing anything?
TIA
« Reply #1 on: October 12, 2007, 02:36:08 PM »
I wouldn't use pagid's on the street much less a track! I would check the compression before you go. And wait till you get there to adjust the tire pressures.  And wait till they are cold, like the next morning.
I would change the fuel filter if they haven't been changed in a while.
n2motorsports
« Reply #2 on: October 12, 2007, 02:37:01 PM »
Your prep work is fine.  I'd also do a radiator flush and add new fluids with some water wetter.  Also make sure you have sufficent tire tread.  Use the tech inspect as a general guideline.
Make a checklist of items to bring as well.  Helmet, snacks, plenty of fluids, tools, jack stand, chair, are things that come to mind.
Most importantly, have fun.
BrandC
« Reply #3 on: October 12, 2007, 05:46:47 PM »
Make sure to check your cooling system parts. Check the clutch fan and make sure your auxiliary fan is working as well.
Going to the track will definitely test any worn/almost broken parts. It can easily ruin your track day.
silverblades181
« Reply #4 on: October 12, 2007, 09:22:55 PM »
Quote from: n2motorsports;35605
Bring a torque wrench/17mm socket if you have one. Tire pressure gauge and compressor. Make sure you have everything to be confortable like n2motorsports said. Usually an HPDE requires a tech form to be completed, if not, make one yourself.
Engine wise I don't think you'll be that hard on it on your first track day (assuming it's your first). You won't be even close to the car's limits although it might happen...I've seen first timers drive like they've been doing this for years. Don't worry too much about the M42....it's a tank and can take a beating.
 Make sure the wheels are torqued in between sessions and it might be good to bleed the brakes mid-day espacially if your using street pads. Are you using a DOT 4 brake fluid? ATE superblue is pretty good.
And most importantly, have lots of fun and learn a ton :D. Track days are addictive!!
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
gwb72tii
« Reply #5 on: October 13, 2007, 02:00:23 PM »
yes, it will be our first day on any track
thanks all who replied. good advice, and i appreciate it!
e9nine
« Reply #6 on: October 15, 2007, 08:14:28 AM »
Brakes :: When I used to take my car to HPDEs I noticed I didn't go through brakes as much as others. This is very dependent on driving style, track and some other variables. One thing to take into mind is with a car like ours you will be on the brakes HARD at the last minute and off earlier than some so you can carry momentum.
Engine cooling: The fan clutch and aux fan only aid a lot in slow traffic. For on the fly cooling, radiator flush, water wetter (not really necessary @ this time of the year for some areas) and you should be good to go. A bad radiator will not cool as well when put to the task. When was the last time your thermostat was changed? How about your accessory belts?
Engine lubrication: Fresh engine oil change with good oil prior to event. Slight overfill of about a quart. Your car will probably be put through it's most intensive test ever. Check oil level religiously, look in the mirror every now and then to see if your car is smoking or ask those who were behind you to see if you were smoking while accelerating or decelerating.
Other fluids: You seem to have that in line. Check, top-off as needed for trans fluid, diff fluid and brake fluid. Tighten these drain bolts to spec. If you bleed brakes make sure bleed screws are tightened and not over tightened.
Suspension: Tighten every bolt and nut that connect brakes, springs, shocks, steering, control arms, tie rods and wheels to spec with a torque wrench. Don't go over board with tightening as that can do more harm than good. If you recently did suspension work, check your strut collar nuts as well.
Tires: Make sure they are in good condition. Air them up nicely and if you're not used to the art of pressure being related to performance, speak with your instructor.
If you have never driven your car @ redline through 1-2-3. Now is the time to try it before you hit the track. Make sure you're familiar with the noises and vibrations that the car exhibits.
When in doubt - pull in to the pits. Most instructors will most likely advise you to pit or pull over the moment something very awkward rears it's head.
On the track: Pay attention listen to instructor and most important of all RELAX and have fun. Set a pace and plan for progression. Talk with instructor. Talk with instructor, talk with instructor, talk with instructor. See if you're confident to admit the areas you want to work on after a few laps. Listen to him. Put ego in container and leave at home too :D
As you start to get faster, be prepared for longer braking distances depending on the style of driving and the nature of the track. Always make sure you check your braking ability gradually prior to going in for the late brake move during the last session when your pads are all but done hehe :rolleyes:
Sorry for the long winded answer. :eek:
2002maniac
« Reply #7 on: October 15, 2007, 10:59:17 AM »
Quote from: asubimmer;35604
meh, Pagids will be plenty sufficient for street tires.
