Indeed, I replaced them with fresh ones.
I am missing the left guide, which I have replaced as well, I'll try to get some pics of the remaining pieces of the guide.
I was driving when this happened, so I kinda limped it home. I imagine this must have done the damage.
Those upper sprockets were toast. I am surprised you are not missing rollers from the chain.
Also, were you missing some guides? Seems odd that it wore into the timing chain housing so bad. Or was it driven for a bit after they broke?
But yeah, with those sprockets, only a matter of time.
Also, that mark (interesting) would make sense for TDC. I will check my e36 motor and see if it is. I take it that mark is on the oil filter piece? And if it is TDC, I may have to re-check timing on my motor, not sure it is correct.
How do I actually use the dial indicator?
I buttoned everything back up, and well...it doesn't good AT ALL.
Strange thing is, it holds idle nice and steady, but there's a metallic noise, kinda like the camshaft lobes hitting the lifters really hard.
I aligned the cams to TDC with the tool, and I did my best to get TDC on the block.
I'm obviously going to tear it down tomorrow again and take a look...
Do you guys have any suggestions?
Is it possible that when the guide shattered, the timing chain skipped a tooth and caused the valves to smack the pistons? I mean...it wouldn't hold idle, would it?
I'm pissed to say the least
