How is my A/F ratio? [log/pics inside]
Author Topic: How is my A/F ratio? [log/pics inside]  (Read 2249 times)
nuvolarossa
« on: October 07, 2007, 01:34:24 PM »
Hi, I hooked up my Innovate LC1...
here are A/F ratios.
All runs are WOT.
Car is 318is M44 NA, without engine mods, innovate lc-1 feeding oem narrowband input
Here are they:
How they are, tell me! looks like ecu want to go 14:1 always:confused:
How they should be?
thank you
tim_s
« Reply #1 on: October 07, 2007, 03:14:45 PM »
yeah looks a bit lean. I found my e30 out lof the box on moronic was similar, at about 13.8:1 throughout. I've had some trouble with my LC1 being accurate, to confirm that the LC1 figures are spot you really need to get her on a dyno.
2.1 200bhp, 175ft/lbs 318is
E46 330ci daily
sumyungguy
  • b.wood
    • http://www.shutterflick.com
« Reply #2 on: October 07, 2007, 03:56:00 PM »
I wouldn't go off of a OEM narrowband.. Like said above, get it to a dyno to get some more accurate wideband readings.
brad™
tim_s
« Reply #3 on: October 08, 2007, 06:54:56 AM »
Quote from: sumyungguy;35200
he's not using an OEM narrowband but an LC1 wideband. Still same applies, I was disappointed with how far out mine was when I went on the rollers. I need to recalibrate, check wiring and take megasquirt out of the equation (I was viewing values in megatune) then retest.
E46 330ci daily
