Author Topic: No gauges working  (Read 3468 times)
COandCA
No gauges working
« on: September 18, 2007, 05:57:27 PM »
Hey guys,
i just swapped in a fresh m42 into my 318is. Everything runs fine, however, when i start the car, the tach will read for a few moments then click off. THe water temp and the fuel gauges do not work either. I know the engine ground is good, fuse is 10 is good, are there any other grounds or relays i should check? could a bad sensor cause it? Let me know what i should look for.
Thanks
COandCA
No gauges working
« Reply #1 on: September 18, 2007, 06:44:54 PM »
i also just realized that my windows will not go down and my reverse lights do not not work. This makes me think there is something crossed up in the wiring
No gauges working
« Reply #2 on: September 18, 2007, 06:54:48 PM »
Yep, time to go back through the harness..
Did you do anything under the fuse box, or under the dash?
COandCA
No gauges working
« Reply #3 on: September 19, 2007, 04:03:59 PM »
Quote from: ak96ss;33933
no. all i did was unplug all the connectors from the motor. Is there a layout where all the plugs from the harness should go? i did it all from memory.
kowalski
  • El\' Duder
No gauges working
« Reply #4 on: September 19, 2007, 06:10:34 PM »
do all your relays click?
Sale:
Fore Sale Thread
Jak318
No gauges working
« Reply #5 on: September 20, 2007, 05:43:37 PM »
Have you figured it out yet CO? I still have the same problem.
Jak318
No gauges working
« Reply #6 on: September 21, 2007, 08:09:07 PM »
Quote from: COandCA;33928
Hey guys,
Thanks
Try checking fuse 12 also. I just solved my cluster problem by replacing it.
Now I just need my turn signals and illumination lights to work.
