Author Topic: new update on BMW 318is Turbo  (Read 8178 times)
vatos_p
may i remind you !!!
« Reply #15 on: September 19, 2007, 02:04:49 AM »
Quote from: ose30;33951
It's great to hear you have done it better than Bosch engineers... No offense, but i have to disagree what you wrote. Tell me even one factory turbo car with Bosch Motronic & AFM which is configured as your car is?  There is no doupt your system will work, but i suppose it will work even better in the way Bosch designed it. I have played about ten years with Porsche 944 Turbo, which has a factory Motronic & AFM with turbo. I have used few piggypacks with MAF & MAP sensors. Piggypacks i have used are SMT6 & AFM Link. SMT6 works better with MAF sensor. AFM Link has a built in 2,5bar MAP sensor.
may i remind you of your words !!!! these are Stock ( factory ) turbocharged cars with AFM.... So Motronic ( and i guess not motronic 1.7 as M42 ) is preset from the factory with a mapping to work like that... My , Our motronic 1.7 , i set to work in that exact place , with vacuum pressure only , the mapping is for stock car from the factory and not turbocharged...
think this only... the AFM is about 20cm away from the intake butterfly... when you press the accelaration petal , vacuum drags air and opens the AFM almost instantly...so the ecu knows that when the throtle is pressed almost instantly air get into the intake ( passing through the AFM and mesured by ) so it knows how much to spray for that air... if you change the possition of the AFM in front of the turbocharger , when you press the throtle , the ecu reads that you have pressed the throtle with the TPS , the AFM reads that air passed though it , and the ecu begins to spray , but the air that the AFM read is not inside the intake anymore , because it has to pass though the turbocharger , though the intercooler , through all the piping to get to the intake , is not 20cm anymore but 1,45m - 1,60m , so all that gasoline that the stock motronic 1.7 sprayed is useless for that specific time... so the engine will be working wrong and more fuel will be sprayed for nothing...Then in more  rpm , lets say 2300 rpm , with the turbo spinning a lot , but vacuum still , ( pressure comes on in 3000 rpm and full boost at 4000rpm ) the AFM will read full vacuum because the air that the turbo sucks in is much more than vacuum stock car at full throtle , so motronic thinks that you are at full throtle with stock car , and sprays like you where at full boost , but you are only in 1/4 of the throtle and going with 2300 rpm...so more fuel will be wasted for nothing...All that becuse the AFM works with pressure diference between the 2 angles that it has...in front of the turbocharger it has vacuum from the turbocharger and atmosphere presure from the other way...but where i have it , i has vacuum pressure form the intake and not atmosphere pressure from the other , but the air coming from the turbocharger witch is always different ( depends on how you drive , how much throtle you have , and rpm ) so it reads more efficiently ... think about it...
there is a slight difference between stock turbocharged car and a car that was designed and mapped non turbo , and a crazy dude like me turbocharged it...
And finaly , Yes i have done it better than Bosch engineers , and BMW engineers because i have puled put 200 hp from a car the comes with 136hp from factory without problems , without damage , and with the less possible increase of fuel consumpion...
what do you say about that.. ???
« Last Edit: September 19, 2007, 02:09:20 AM by vatos_p »
steer with the rear !!!
ose30
« Reply #16 on: September 19, 2007, 10:30:56 AM »
Porsche 944 turbo's Motronic is even older than M42 engines have. 944 Turbo came to the market in June 1985. Same Motronic was used between 1985-1987. For model year 1988 Motronic was changed a little bit when they moved from 4K 24 pin eproms to 8K 28 pin ones. Then they were able to place all parts of fuel & ignition maps to same place. Motronic version did not changed, all 24 pin Motronics can be easily convert to 28 pins. Have done many of them.
Motronic actually does not know there is a turbo installed. There is an additional computer called KLR handling pressure/knock etc. So in that case there is no advantage compared to turboed M42 engine what comes to Motronic, of course chips map is designed to turbo charged car.
Only the boost control & knock is handled with KLR box which drives cyclic valve and wastegate. I still prefer the way Bosch designed it, also your car should work better the "Bosch-way", there might be a need for remap the chip, but i suppose also with your way to install AFM  (with turbo) you cannot have optimal A/F ratio just with piggyback and standard chip and it would be good to have your cars chip optimize for turbo application
