So I am all excited to put on my M tech II steering wheel. I had heard that I need a spacer because the wheel sits too far down the shaft and the locking nut will not reach it. So I got a 3/4' steel spacer, placed the steering wheel on the shaft, put the spacer on,(fit perfectly), then the washer followed by the locking nut. Great. Fits fine. THEN as I turn the wheel, the white plastic pin that sticks out from the collum in between the rear of the steering wheel and the collum, ( it is the white pin that needs to be pushed in so the steering collum locking mechanism will release ) is getting caught and not unlocking!!!!!!!!! Does anyone have any words of wisdom to get around this and make the steering wheel work?
