DISCUSSION
Engine + Driveline
Propshaft centre bearing question
Topic: Propshaft centre bearing question (Read 3225 times)
anisotropy
September 11, 2007, 02:29:49 PM »
After splitting the prop shaft and removing the circlip and dustguard does the centre bearing just slide out or do I need a puller or something? doesn't seem to want to come but haven't seen it mentioned anywhere.
Cheers guys.
dhirsch
September 19, 2007, 04:50:25 PM »
You can use a puller to get the bearing off the prop shaft, or use a drift or screwdriver and lightly tap them with a hammer to work the bearing off the shaft. Just make sure you keep moving the drift or screwdriver around the entire bearing.
DZick
September 22, 2007, 09:07:13 AM »
I used hammer and screw driver and it worked great.
Just don't forget to preload the bearing, otherwise you will be back under there in about a month.
Dan Zickel 30stx
Solo Performance Specialties
madman mike
January 28, 2008, 06:56:04 AM »
Forgive my ignorance here, but what exactly do you mean by preload? I am going to have to perform this operation soon.
thanks
mike
DZick
January 31, 2008, 08:22:09 PM »
Pull the CSB back so that there is tension on the bearing making it not want to move all around.
Sorry Kind of hard to explain
Basically
1. Grab the metal piece that connects to the rubber (after it is already reinstalled under the car and the only thing left to do is connect the 2 screws.
2. Pull back approx 2-3in
3. lock it down tight
You just dont want the drive shaft to be able to move up and down alot while spinning (tears aparth the rubber peice and is the reason for replacement). When you pull back on it it stretches the rubber and the DS cannot bounce around
Dan Zickel 30stx
madman mike
Reply #5 on:
February 06, 2008, 07:32:59 AM »
Thanks. I picked up a bentley with the parts. That job is a done deal. Now to figure why my fuel pump crapped out.
DISCUSSION
Engine + Driveline
