Author Topic: COP Conversion Brackets  (Read 65223 times)
haledj
« Reply #45 on: December 23, 2007, 10:05:30 PM »
Quote from: jakeb;39939
Do you know which plug goes to each coil?
I am swapping into a 2002 and not everything on the harness is labeled.  Two of the leads are together and the other two are on their own.
does this make sense?
It does but I do not know how to help you, I had to trial/error mine.
There are 24 different possible combinations:confused:
haledj
« Reply #46 on: December 23, 2007, 10:11:49 PM »
Quote from: D. Clay;39943
The valve cover is wider at the top than where the original cover fit. I have had a new cover on my do list for some time but have never gotten around to it. It would be easy to secure it to the COP plate. I was going to get black plastic (heat resistant) and make one and try some different logos, etc. Unfortunately, I've always had two or three things on my to do list ahead of it. If any one else does something nice I would be interested in one.
I might be making something...  We'll see.
jakeb
« Reply #47 on: December 23, 2007, 10:24:59 PM »
Quote from: haledj;39949
haha so you just plugged them in and started swapping until it ran right?
Maybe I will pull the wires on my stock e30 318is and see which is which.
jake
http://www.classicdaily.net - swapping this into that
http://www.blunttech.com - all your parts needs
haledj
« Reply #48 on: December 23, 2007, 10:28:23 PM »
Quote from: jakeb;39953
jake
Yeah something along those lines, I had it narrowed down somehow.  I had labeled them but I did something wrong, so guess and check it was.
« Reply #49 on: December 24, 2007, 12:54:27 AM »
Bah, lucky man having a bench grinder/polisher.
haledj
« Reply #50 on: December 24, 2007, 01:32:31 AM »
Quote from: bmwman91;39958
yeah, its alright.  We have a couple different bench grinders and a bench polisher with two different stiffness of polishers.  Sometimes I just polish things because I'm bored. /super arrogant sarcasm
sports.racer
« Reply #51 on: December 24, 2007, 04:45:42 PM »
Got my bracket thanks.
One question, is the seal for the hold down bolts not being used for this? I take it no leaks are happening without that seal?
Items 8 and 9.
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_0264&hg=11&fg=15
haledj
« Reply #52 on: December 24, 2007, 04:49:12 PM »
Quote from: sports.racer;39991
Items 8 and 9.
I cut those bolts in half to get the seal and washer off and am using them on the stud.
BrandC
« Reply #53 on: December 25, 2007, 06:34:04 AM »
So from what I understand, S52/M54 coilpacks are plentiful and hook right up to the resistor connector?
haledj
« Reply #54 on: December 25, 2007, 09:38:27 AM »
Quote from: BrandC;40006
I used the m54 coils, I do not know about the S52 ones (are they the same?)
And yes, plentiful they are.  (They hook up too!)
P. Kennedy
Plentiful?
« Reply #55 on: January 02, 2008, 09:26:16 PM »
Well...I am having a heck of a time finding reasonably priced coils for my COP conversion.  $50 / coil isn't terribly economical when a decent set of wires can be had for $85.  Turner does not have the correct ones.  I'm HOPING for something around $25 / coil, and I'm not giving up yet.  If someone happens upon a deal, let me know and I will be eternally grateful.
haledj
« Reply #56 on: January 04, 2008, 12:41:34 PM »
I used used coils I found on e46 fanatics,  they often replace perfectly good coils with "High performance coils," so I have found that the supply exceeds the demand for the used coils.  I got mine for $10 each with 15K miles on them.
P. Kennedy
Yes indeed
« Reply #57 on: January 04, 2008, 01:00:24 PM »
I camp out on e46 Fanatics almost every night, searching high and low.  Haven't gotten lucky yet.
haledj
« Reply #58 on: January 04, 2008, 01:18:19 PM »
Did you post a wanted thread? I had a lot of luck with that.
rfritz
« Reply #59 on: January 04, 2008, 01:45:55 PM »
So with these you don't have to cut the harness? I already started to disect mine.....:mad:
Quote from: haledj;40008
