Author Topic: Oil consumption tracker  (Read 3850 times)
badboypolar
« on: September 05, 2007, 12:02:01 PM »
So I want to try to put together a baseline for oil consumption for our cars/engine. This will only apply to those who are still m42 and not under boost. Sorry but N/A only. Also no cams, stroker kits or major head work (no porting & polishing; shaved head okay as long as a thicker head gasket was installed).
So if everyone would be so kind as to list:
Production Date:
Mileage:
Oil consumption per 1000 miles/1609 km:
Oil Weight:
Last Oil change Date/Mileage:
Mods like I/H/E/CC/MC:
I = Intake
H = Header
E = Exhaust
CC = Catch Can
MC = Modified Chip
badboypolar
« Reply #1 on: September 05, 2007, 12:04:49 PM »
Production Date: 05/1990
Mileage: 223764
Oil consumption per 1000 miles/1609 km: 1 qt
Oil Weight: Lubromoly 10w/40 Semi Syn mos2 anti-friction
Last Oil change Date/Mileage: 8/1/2007; 221700
Mods like I/H/E/CC/MC: Shaved head; used thicker head gasket to compensate; also have .50mm over pistons; rebuild done 3000 miles ago
« Reply #2 on: September 05, 2007, 09:48:44 PM »
All original motor except for TB heater plate deleted. 200,000  miles. I don't add oil between changes. Usually 1/2 quart or less low.
Castrol GT. straight 30 wt if available, otherwise 20W-50 every 3000 miles.
Does the catch can collect any oil?
« Reply #3 on: September 06, 2007, 01:27:47 AM »
1) Production Date: 06/1990
2) Mileage: 155438
3) Oil consumption per 1000 miles/1609 km: 1/3 qt
4) Oil Weight: Mobil1, 15W-50
5) Last Oil change Date/Mileage: ??/??/2007; 145,XXX (Yes, you can go 10k on full synth, easy.  Just swap filters every 5k or so to be safe)
6a) I - MAF Conversion, that's all.
6b) H - Stocker
6c) E - Supersprint Cat-Back, OEM Cat
6d) CC - Stocker
6e) MC - Jim Conforti Chip
7) Other: I HAVE rebuilt the timing case and replaced all the gaskets on there, as well as both the upper & lower oil pan gaskets.  I also repaired the threads for the valve cover bolts and replaced all the gaskets for the valve cover.  That helped a LOT.
« Last Edit: September 06, 2007, 09:26:48 AM by bmwman91 »
Naked Assault Gerble
« Reply #4 on: September 06, 2007, 09:08:54 AM »
(For the 318is)
Production Date: 10/1990
Mileage:140,xxx
Oil consumption per 1000 miles/1609 km:Maybe 1/3 a quart if that
Oil Weight: Castrol Gtx 10w40
Last Oil change Date/Mileage: 09/05/2007 139,xxx
I = Stock
H = Stock
E = Rusted to hell
CC = None
MC = Stock
(For The 325es)
Production Date: 09/1985
Mileage: 236,xxx
Oil consumption per 1000 miles/1609 km: None as far as I can tell :)
Oil Weight: Castrol Gtx 20w50
Last Oil change Date/Mileage: 234,xxx 06/xx/2007
I = Stock
H = Stock
E = Custom 2.5in from headers to a glass pack to some off brand muffler
CC = none
MC = FleaBay chip
strad
« Reply #5 on: November 08, 2007, 09:43:14 PM »
Yayy.  was hoping for a thread like this.  Between leaks from the pan gasket and burning, I'm at about 1/2 quart per 1500 miles.  197k miles on motor.
Engine is completely stock, right down to the original hoses (and vacuum leaks!) under the manifold lol.  I'll be changing them next week.
Production Date: 09/90
Mileage: 197.5k
consumption per 1k: 1/3rd quart
oil weight: Castrol 10W40
Last oil change: 196k
« Last Edit: November 08, 2007, 10:01:31 PM by strad »
n2motorsports
« Reply #6 on: November 08, 2007, 11:01:59 PM »
Production Date: no sure
Mileage: 180,xxx
Oil consumption per 1000 miles/1609 km: 1/4 quart
Oil Weight: 10w/40
Last Oil change Date/Mileage:176,xxx
Mods like I/H/E/CC/MC: MC
christophbmw
« Reply #7 on: November 09, 2007, 09:37:44 PM »
Production Date: 02/1991
Mileage: 190,000
Oil consumption per 1000 miles/1609 km: maybe 1/4q at very most.
Oil Weight: 10/30 in the winter, 15/40 in the summer. Swepco.
Last Oil change Date/Mileage: august some time, i cange it every 5K
Mods like I/H/E/CC/MC: resealed the entire motor 35K ago. and i rev the heck out of it (when its up to operating temp...never below 1/4 temp), i baby the motor, but im also EXTREMELY hard on it.
biljak
    • http://www.zsem.hr/~blezaic
« Reply #8 on: November 10, 2007, 04:59:58 AM »
Production Date: 1990
Mileage: 222.000 km
Oil consumption per 1000 miles/1609 km: 1.2 L per 1600 km
Oil Weight: 10W40
Last Oil change Date/Mileage: 06/2007 @ 215.000
I = Intake ( http://www.sole.hr )
E = Exhaust ( http://www.auspuh-lastovcic.hr )
