Update from death...
PC3 can easily work with a MAP sensor, the only thing is that you have to configure it in its software.
As I'm here I want to say to all people that is thinking about fitting a PCIII that there will not be possibility to control ignition timing.
Today I chatted with Dynojet staff asking them if their ignition modules works on our cars, showing them the S.Fogg write up.
In the end we figured that the ignition modules are coupled with a power commander for the same bike, otherwise it will not work, so a suzuki 1000 ignition module works only with a suzuki 1000 PC3, and so on.
Then suzuki gsx-r 1000 (we can use PCIII from that bike) use a 24-2 toothed crank wheel, and our is 60-2, so it will not work, and dynojet will not change it for us because there isn't such a market.
Another thing is that wiring a PC3 to a car will void the warranty. (but they can't see if it's happened
There is NO WAY to expand Power Commander III to control ignition timing.SO UNLESS YOU'RE AIMING FOR LOW-MID BOOST ON SUPERCHARGER, STAY AWAY FROM POWER COMMANDER, EVEN MORE IF YOU'RE USING A TURBOCHARGER, WHERE IT'S EASY TO RAISE THE BOOST AND MAKE DAMAGES.
Ignition timing is fundamental when over 8psi of boost, for a long and safe life of your engine.
Hope that this message will be useful.
bye
