Author Topic: Warm start issues  (Read 3417 times)
Intense
Warm start issues
« on: August 22, 2007, 08:51:27 AM »
Hey all,
Hoping you can help my diagnose a problem.
On warm starts, my engine takes a couple cranks before it catches and then it runs like crap for a minute or so.  After that, whatever issue I have clears up and she runs fine.  In that first minute, the engine will stumble and hesitate and occasionally die unless I give it some gas.
Cold starts (sitting overnight), do not seem to exhibit the same behavior.
When I bought the car a couple months ago, she didn't exhibit the same behavior.  Initially, I thought it was the fuel pump.  But after reading a couple threads, I'm re-thinking that.  I need to put a fuel pressure gauge on the fuel line to see if it's dropping off when I let her sit.
Beyond a fuel system problem, what else could it be?
thanks
bmwpower
Warm start issues
« Reply #1 on: August 22, 2007, 09:04:51 AM »
Could be plugs.  Crappy plugs/non factory platinum type can cause that, too.
Leaky injector.
Intense
Warm start issues
« Reply #2 on: August 22, 2007, 09:13:54 AM »
Quote from: bmwpower;32205
Leaky injector.
Interesting, what are the brand/style of plugs are recommended?  gap?
I haven't smelled any fuel after I turn off the engine and let it sit.  So, I ruled out injectors
bmwpower
Warm start issues
« Reply #3 on: August 22, 2007, 02:58:53 PM »
Quote from: Intense;32206
I don't have the correct part number with me, but it should be in your manual.
I meant an injector might be leaking INSIDE, essentially flooding the cylinder with gas.
Vladi
    • http://www.bmwzone.ro/forum
Warm start issues
« Reply #4 on: August 22, 2007, 05:12:08 PM »
NGK BKR6EQUP or NGK BKR6EK are recommended by BMW.
ABuseO
Warm start issues
« Reply #5 on: August 28, 2007, 10:58:10 AM »
I am having this exact same problem. It starts fine over night, but when you start it up after you've driven it somewhere the engine seems to be lacking, but after about 2 minutes it seems to run fine.
I assumed it was the fuel pump too, but i havent had time to experiment with it.
Let me know if you find out whats going on.
Austin
johna
    • My BMW 3 Series Website
Warm start issues
« Reply #6 on: August 28, 2007, 04:51:49 PM »
It may be worth cleaning your throttle body and air flow meter as I had a similar problem and much to my suprise it was cured by doing this.
P. Kennedy
Warm start issues
« Reply #7 on: August 28, 2007, 05:26:44 PM »
What did you use to clean with?
johna
Warm start issues
« Reply #8 on: August 28, 2007, 08:41:28 PM »
Throttle body cleaner (carb cleaner that is suitable for EFI throttle bodies would be fine too).
badboypolar
Warm start issues
« Reply #9 on: August 29, 2007, 10:46:19 AM »
I had that problem and I did two things that fixed it. First I replaced my injectors as I had a leaky injector. This by itself is a problem that will cause it. After I replaced the injectors I still had some hesitation when warm.
So I replaced my AFM, which fully cured the problem.
Don't under-estimate what replacing the AFM can do.
