Author Topic: Read my Plugs  (Read 3638 times)
badboypolar
Read my Plugs
« on: August 21, 2007, 12:01:27 PM »
So I went to do a compression test, just to be sure everything is okay. Look at my spark plugs. I know something isn't right but I can't remember what it means. Either I am not using a high enough octane, though I'm using 91, or my plugs are too hot or cold.
Read my Plugs
« Reply #1 on: August 21, 2007, 12:24:30 PM »
I am not sure about the plugs...but what camera are you using?!?!
badboypolar
Read my Plugs
« Reply #2 on: August 21, 2007, 03:25:44 PM »
It's a Nikon D50 DSLR.  Using a Nikor 24-120mm, 72mm lense.
The lense makes all the difference. The camera is awsome, but the lense is what really got those shots.
biljak
    • http://www.zsem.hr/~blezaic
Read my Plugs
« Reply #3 on: August 23, 2007, 06:40:01 PM »
i have a similar problem, but only on the 4th cylinder (closer to the cabin). i have to clean (sandbrush?) the plug every couple thousand miles and it runs fine after that. i heard that these things can build up on the spark plug because the oil burns inside the cylinder. never did give it too much attention dough...
kowalski
  • El\' Duder
Read my Plugs
« Reply #4 on: August 24, 2007, 01:30:14 AM »
white means your running lean does it not?
Sale:
Fore Sale Thread
Read my Plugs
« Reply #5 on: August 24, 2007, 12:15:03 PM »
Quote from: biljak;32317
The top electrode looks a little closer than the bottom one and is getting hotter. It is eroded more also. Oil getting into cylinder. Regap and swap coils to see if problem moves to another cylinder.
Read my Plugs
« Reply #6 on: August 24, 2007, 12:20:33 PM »
The inside back cover of a Hayne's Repair manuals has very good pictures of common plug conditions
rhogg
Read my Plugs
« Reply #7 on: August 24, 2007, 07:03:13 PM »
As does the web. One of many: http://www.beru.com/english/produkte/zuendkerzen/diagnosehilfe.php
Yours don't look bad, but well aged. How many miles on them?
silverblades181
Read my Plugs
« Reply #8 on: August 24, 2007, 07:28:20 PM »
Quote from: rhogg;32391
They don't look that bad, maybe running a little lean.
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
kowalski
  • El\' Duder
Read my Plugs
« Reply #9 on: August 26, 2007, 02:27:04 PM »
Quote from: D. Clay;32356
the spark only comes of one side of the plug, the closer side. Path of least resistance.
Sale:
Fore Sale Thread
badboypolar
Read my Plugs
« Reply #10 on: August 27, 2007, 01:09:06 PM »
There are about 1,700 miles on those plugs.
