M40 flywheel= 22 lbs. Can be reduced to 16-18lbs with machine work. Mine came out at 17.6 lbs. IIRC the M20 will be lighter, but you have to change the starter gear, or the ring gear on the flywheel. M20 allows for a bigger clutch, which equals more weight, but also handles more power if needed. Non AC M42's have the M40 flywheel. Most US 318is' have AC. I got lucky and found one for sale on e-bay, by a salvage yard in Georgia. $75 shipped. Best mod I have done next to the Mark D chip. Dramatically improved throttle response.
