Author Topic: Oil pan return line: drill and welding tips?  (Read 2876 times)
nuvolarossa
« on: August 14, 2007, 04:12:25 PM »
Hi, there are particular tips of doing this on a m44?
What material is the oil-pan?
Is good welding it with MIG, or TIG is the only way to go?
bye
« Reply #1 on: August 14, 2007, 06:30:04 PM »
TIG would be best on it since it is a cast part, and TIG has the most localized heat.  However, you should get by fine with MIG on it.  The only concern when welding cast parts is cracking them, but based on the shape of the oil pan it should be fine for an oil bung.
nuvolarossa
« Reply #2 on: August 15, 2007, 06:56:17 AM »
Quote from: bmwman91;31610
is it aluminium?
I'm asking because I haven't gas for MIG, so if it's alu I need to buy the gas:D And if it's other metal, I'll weld it with no-flux core wire:)
Naked Assault Gerble
« Reply #3 on: August 15, 2007, 09:12:25 AM »
Yes its cast aluminum.
