Author Topic: How tight to make the belts?  (Read 2243 times)
nomad
« on: August 13, 2007, 07:47:51 PM »
I replaced the belts and everything's cool but I'm wondering how tight I should have made them. I don't want to put undue pressure on the waterpump shaft bearing or the PS pump etc.
I'm thinking I may back them off some and see if I get any slippage.
Any "rule of thumb" to go by?
SoCal, 318is: IT RUNS AGAIN!
rhogg
« Reply #1 on: August 13, 2007, 08:16:24 PM »
A number of the DIYs suggest 1/4" deflection. I found this too tight. Trial and error to find the softest setting that didn't  squeal was what I did.  Keep track of the notches on the tightening track as you do this, and you'll have it dialed in  in a couple of  attempts.
Shocker
« Reply #2 on: August 13, 2007, 10:37:49 PM »
The factory adjusters will strip out way before you get your V belt to tight.  As long it doesn’t squeal its fine.  1/4” play/Deflection is perfect.
nomad
« Reply #3 on: August 14, 2007, 09:26:25 AM »
Guess I'll back them off slightly then.
And yes, those factory adjusters are rediculous.
