Author Topic: Stupid Cooling System  (Read 3197 times)
« on: August 06, 2007, 07:33:35 PM »
Talk about luck.  I made the just 287 mile drive both ways without overheating.  My car seems to be leaking coolant FAST.  After pulling the fan & stuff off, it seems to be dripping out from behind the water pump pulley.  I am currently waiting for the motor to cool off so I can disassemble it further.  I am praying it is just the O-ring on the pump, but I bet it is the shaft seal.  I swear I can hear the sound of a pooped pump when I shut it off.  I guess I will be ordering a new pump soon.  D'Oh!  Of course I did not realize that it was leaking this badly until Talk about luck! I lost about 1L of coolant per 287 miles!  Ignorance is bliss...had I checked carefully down there I would have probably ordered a part there and had to take another day off of work.
Details to come.  Maybe some pics.
badboypolar
« Reply #1 on: August 06, 2007, 09:59:55 PM »
I had the same problem last week. The shaft seal blew and I was leaking coolant like mad and my water pump only had 2200 miles on it.
« Reply #2 on: August 06, 2007, 11:58:42 PM »
Damn, that blows.  It seems that the only ones available anymore are the crappy plastic-impeller ones, and the marginally better cast iron impeller ones.  The OEM one had a really nice brazed sheet-aluminum one, and I have never seen an equal replacement.  A local shop had one in stock, an Airtex one, and I went with it for $58 since I have to drive to work tomorrow morning.  Not a bad deal, all in all.  I replaced the t-stat O-ring and applied some special cooling system gasket sealer around it.  A bit of advice...don't plug that little passageway in the housing...you cannot get the air out without it clear!  Phew, shower time!
Vladi
    • http://www.bmwzone.ro/forum
« Reply #3 on: August 07, 2007, 04:39:27 AM »
Just changed my water pump yesterday also, had the nice shiny one. It didn't have any problems but i changed it anyway for my peace of mind. The replacement has cast iron impellers.
badboypolar
« Reply #4 on: August 07, 2007, 01:34:58 PM »
My replacement was from BMW and had the alum impeller. It was almost twice what you paid though.
« Reply #5 on: August 07, 2007, 05:49:07 PM »
Huh, I guess my car has had the pump replaced. It has a cast iron impeller, which I thought was stock. Previous owner didn't mention that...
christophbmw
« Reply #6 on: August 07, 2007, 07:26:45 PM »
Quote from: badboypolar;31175
yeah but yours will last twice as long ;). i have 185K on my original one, when i did the rebuild 45K ago the water pump was the only thing i did not replace, i did not replace it because the one i was going to replace it with had a plastic impellar.
With my 16 canoe ontop of my car at 75MPH in 104 degree whether with the car FULL of camping gear while going UPHILL with the A/C on, the needle stays pegged at the center mark on the temp gauge....you gotta love the M42 :rolleyes:.
thebigbadyeti
« Reply #7 on: August 09, 2007, 03:20:36 PM »
Pelican parts sells a metal impeller one for a reasonable price. they also have the water pump super kit. I guess for super peace of mind?
