Author Topic: Not starting, holding charge?  (Read 2160 times)
JR Lupton
« on: August 05, 2007, 10:38:40 AM »
This topic might be posted in the wrong section....
I have a problem with my 1991 318is. Here it is......
If I let the car sit for between 24+ hours it won't start.
But if I boost it, it starts right away.....and will hold charge for the time posted above. It varis though, but 24 hours is generally the max.
I tryed charging the battery last night, and when I put it back in it does the same.
I then tried hooking up my battery from my VW golf, running booster cables from it to my cars terminal wires.
Sooo, does this sound like a starter, an alternator or maybe a solinoid? Anyone with any similiar problem experience or suggestions, I would appreciate your feedback!
thanks,
JR
p.s I'm having trouble uploading pics for the intro section....mine are too big
« Reply #1 on: August 05, 2007, 11:03:46 AM »
Did the battery from the VW work OK?
Sometimes the switches for the trunk light and the glovebox light can stick, and that can drain the battery enough in a short time for the car to have trouble starting.
JR Lupton
« Reply #2 on: August 05, 2007, 11:43:51 AM »
no, it didn't start with the VW battery:confused:
JR Lupton
« Reply #3 on: August 06, 2007, 04:02:05 PM »
Not sure if this is under the wrong section or not?
UPDATE:
I replaced the battery and that seems to have fixed it.
However, I removed the cd player(aftermarket) to fix up the wiring and can't get the unit powered up?
I followed the color codes from the "How to" section but no power? Even stranger is when I attempt to hook everything up to the head unit harness, it blows the fuse for the RPM gauge.....
I think my car is possessed!!
b318isp
« Reply #4 on: August 07, 2007, 07:26:34 AM »
Nothing to do with the CD, but it may be an idea to check the voltage of the car when running - should be a little over 14 volts if the alternator brushes are OK.
