You could try this stuff.
http://www.eastwoodco.com/jump.jsp?itemID=248&itemType=PRODUCT
That's not a bad idea. I may try that. They have a good zinc plating kit as well I was looking at. But, I know nothing about the quality of thier products although I know they are geared more towards the American iron.
I may also try the body shop supply custom mix idea as I'm going to already have them make me a few good small spray cans of Alpenwiess II. I plan to sand and hit a quick coat on a few areas in the engine bay while the motor is out. I'll at least check there first and see if they have any suggestions. I'd rather us a high-temp application paint on the VC and IM though.
I painted my AFM a few weeks ago with some high-temp silver. Looks much better than it did (the aluminum on mine looked awful and so I decided to sand it down, clean it and shoot it with paint). Looks like one chunk of solid aluminum now which is cool!!!
Once sanded and totally clean, you have to be sure it's taped up really well!!! Paint on the "hot wire" sensor would not be good for it! After that, I hit it with a self-etching primer.
Then after applying several thin coats of silver engine paint, it begins to look like this.
And, here it is installed. It's a little brighter than I'd like (which is why I want something a little less "silvery" for the VC and IM). But, overall, I think it came out pretty good. it actually stands out a lot in this pic because of the flash.
What do you guys think?? I know it's a totally useless mod, but I was bored and wanted to play around with painting some bits.
