Author Topic: Fuse #10  (Read 4587 times)
brooklyn318
Fuse #10
« on: July 30, 2007, 10:11:29 AM »
This is killing my patience. Fuse 10 is the fuel/tach/temp gauges, AC/heater blower, back up lights, stereo (I think) maybe a few other components. The wiring appears to be fine. Fuse tends to blow under hard braking. That should tell me something, what, I don't know. Anyone else ever have this problem (and a fix hopefully)?
sheepdog
  • Site Admin
Fuse #10
« Reply #1 on: July 30, 2007, 12:00:10 PM »
Check your brake lights.
May want to replace the bulbs, one may be bad and drawing more current.
johna
    • My BMW 3 Series Website
Fuse #10
« Reply #2 on: July 30, 2007, 04:42:21 PM »
I had a similar problem on the same fuse... It was the reverse light switch where it passes through the body through the gear lever rubber grommet. Replace the fuse and with the ignition on go though all the gears and see if it blows again. And lift you gear lever leather surround and check the wiring insulation hasn't been worn through on the wires there.
brooklyn318
Many Thanks
« Reply #3 on: July 30, 2007, 05:35:39 PM »
The brake light was fried at the base. Was not original equipment and someone had forced a bulb in there. Thanks to you both I saved a trip to the mechanic.
sheepdog
  • Site Admin
Fuse #10
« Reply #4 on: July 30, 2007, 09:49:24 PM »
Glad you fixed it.
Sometimes it is the strangest things that cause it.
Bl0mgren
Fuse #10
« Reply #5 on: July 08, 2011, 11:25:05 AM »
I have same problem with fuse 10, changed cluster and disconnected reverse light switch. help! :)
Bl0mgren
Fuse #10
« Reply #6 on: July 24, 2011, 04:57:26 PM »
Finally found the issue with fuse #10 in my car.
Additional water pump   p.n. 64118390090
Fuse #10
« Reply #7 on: July 24, 2011, 06:14:47 PM »
How much power was the aux pump pulling?  We didn't get many of those...they tend to freeze up, don't they?
I always thought those little pumps would be a good solution for motorcycles though...
