Author Topic: coil resistance test; anyone know the ohms?  (Read 4254 times)
TomO2UT
« on: July 23, 2007, 08:54:18 PM »
Does anyone know of a coil resistance (impedance) test? Does anyone know the ohms? I was told by a Roundel TSA rep there is no test for these coils. From a few forum posts here and PMs I heard to check the outer two pins: it should be under 0.8 ohms (about 0.3 or 0.4 up to 0.7 ohms). I get 1.0 to 0.9 on all four of my old coils. I tested a new Bremi coil and got 1.3 ohms.  I was guessing I had a bad coil because of a bad intermittent engine misfire.
Vladi
    • http://www.bmwzone.ro/forum
« Reply #1 on: July 24, 2007, 04:54:50 AM »
Here ya go. Have phun. :D
sports.racer
« Reply #2 on: July 24, 2007, 12:14:21 PM »
According to that table your new one is no good either.
Measure the resistance of just your test leads and subtract that from the reading through the coil.
TomO2UT
Thanks; Plug wire/connector resistance?
« Reply #3 on: July 24, 2007, 09:23:15 PM »
Thanks guys, my meter was reading erratically below 1 ohm, so I bought another multimeter. While I'm at does anyone know what the spark plug wire and connector resistance should be? (Guess I need to buy yet another Bentley manual.)
I get 6.3 to 6.55 k Ohms on my 4 plug wires/connectors.
« Last Edit: July 24, 2007, 09:41:35 PM by TomO2UT »
