Engine re-build
Author Topic: Engine re-build  (Read 2146 times)
All Tiied up
Engine re-build
« on: July 23, 2007, 04:15:23 PM »
Hi there,
I am about to embark on a heart transplant (engine that is!) ;)  Changing the orginal M10 engine for the M42 engine
The car will be mainly used for road use, but also some track days.
What would you do on a complete engine strip and re-build, modyfying any faults, that over the years have been recognised and corrected.
Also, performance of the engine will be sensibly played with :cool:, any sugestions?
« Last Edit: July 24, 2007, 01:20:09 AM by All Tiied up »
If it doesn\'t feel right.....don\'t do it!!
Laughter is the best medicine :D
Engine re-build
« Reply #1 on: July 23, 2007, 06:00:24 PM »
bore or stroke it.  And it depends if you ever plan on goin FI you may want to lower the compression or if you stay N/A then raise the compression ratio.  Goodluck ;)
