I am watching this intently. Hopefully you will have good results!
Hey, thanks!
After doing some research at various LED forums around the web,
it became clear to me, that a full low beam conversion isn't quite practical yet.
The technology is almost here, and it's quite possible but not practical.
There are a few options if going full low beam conversion (at least it's how I imagine it):
-Use ~6-7 Lumileds Rebel LEDs surface mounted on LARGE heatsink, a
nd drive each of them @ 1Amp current,
so each one would be outputting ~200lm.
Some kind of active cooling should be required in this case,
as their efficiency would be about 63lm/w
-Use ~12-14 Lumileds Rebel LEDs surface mounted on LARGE heatsink,
and drive each of them @ ~300mA current,
so each one would be outputting ~100lm.
Active cooling may be required for those very hot days,
as the efficiency is this case is quite high @ 100lm/w
-Use
this monster, and worry even more about cooling,
as efficiency of this monster, well, sucks just @ ~34lm/w
Non of these options is easy, because in each case the total vdrop across the LEDs is more than 12V,
this means wiring them in parallel, which requires additional voltage/current regulators, hence more complexity,
also I don't think any of these options could be cooled passively without requiring a massive heat sink,
or some modern technology like heat pipes.
Also fitting all this in the beam assembly is quite a challenge, even in case of the e36 beams, which have quite some room.
The other challenge is "conditioning" the light produced by the LEDs before it hits the stock lens.
As LEDs produce quite a concentrated light, some kind of optics should be used to spread it out more evenly.
But this is quite possible, because wide angel lenses are common for popular LEDs.
There are ofcourse other problems that one will encounter, if taking on this challenge.
But it is possible, I know at least one guy who did a full High/Low beam conversion for his friends truck,
and I can link to his thread if someones interested, although, the server with his pics is down,
so there is nothing to look at except some 15 pages of boring text.
I personally still believe, that in some 2-3 years such conversion would become even more practical,
for now though, using LEDs for anything more than DRLs is not quite practical IMO…
