Author Topic: E36 318is Turbo MANIFOLD  (Read 13448 times)
Tor Arne Kaasen
« on: July 21, 2007, 11:33:50 AM »
Hi guys! I am trying to build a turbo manifold. The space is different to the e30 is. the shcock absorber tower is less tilted and a tad forward.
I bougt the Ebay e36 inline 6 turbo manifold, and chopped of the two last pipes. I ended upp whit the turbo to close to the head and it thouches the shock tower. do any body have any pix of a manifold?
Yes i now is a M43 engine but same car
« Last Edit: July 21, 2007, 01:14:22 PM by Tor Arne Kaasen »
BMW E82 120d Coupe and BMW Z3 1,9 m44
jon volk
« Reply #1 on: July 21, 2007, 02:03:32 PM »
nuvolarossa
« Reply #2 on: July 22, 2007, 01:41:28 AM »
:eek: tell us the price of that beast!
« Last Edit: July 22, 2007, 01:51:44 AM by nuvolarossa »
Tor Arne Kaasen
« Reply #3 on: July 22, 2007, 04:04:17 AM »
:eek:that`s crazy,
nuvolarossa
« Reply #4 on: July 23, 2007, 01:40:45 AM »
Quote from: Tor Arne Kaasen;30058
ops, I haven't read this . But it seems that you want to fit it for top mount, right??? If you rotate the manifold for bottom mount it fit right?
bye
Tor Arne Kaasen
« Reply #5 on: July 23, 2007, 05:28:15 AM »
i want it to be topp mounted, but if it isnt poseible, the sleeper it is.
Must make new engine moutening then. it is in conflict with the compressor inlet.
« Last Edit: July 23, 2007, 06:36:08 AM by Tor Arne Kaasen »
nuvolarossa
« Reply #6 on: July 23, 2007, 02:14:41 PM »
Quote from: Tor Arne Kaasen;30152
It's bad that it's hitting the motor mount... Do you plan solid motor mounts? If you'll build them post pics and tell me if they lower too the comfort;)
Frankie
« Reply #7 on: July 23, 2007, 02:17:55 PM »
Well, that manifold is far from good exhaust manifold. The exhaust pulses won't travel freely and it will surely show (majorly) in dyno.
Tor Arne Kaasen
« Reply #8 on: July 23, 2007, 04:04:03 PM »
The manifold isn`t fantastic, its cheap China stuff. I know, but at 120usd.
The car isn`t for good dyno. its for smal trak running and funn.
That`s why i got the GT2860rs and not the GT2871R
I have seen people use oem manifoilds and just a colector tube stright in the turbo. it works.
And this must be better than that.
the eksos pulses are separat just before they hit the turbo, and thats a god thing. but not equal lengths.
Ok if i had a ton of cash, i would go for fab666 manifolds and offcourse the intake manifold.
The volvo 740tic 2,3 turbo uses a cast manifoild whith sharp angels and a stoneange t3. was able to squees some power out of it to.
« Last Edit: July 23, 2007, 04:06:54 PM by Tor Arne Kaasen »
ose30
« Reply #9 on: July 24, 2007, 01:12:56 AM »
Tor Arne,
are you using this manifold?
Frankie
« Reply #10 on: July 24, 2007, 01:26:00 AM »
Quote from: Tor Arne Kaasen;30178
Well, dyno is good preparation for track driving and significant part of your work will be affected by that crap manifold. Try to find a a manifold which has  equal length of pipes. Otherwise it will affect the fuel burnig process and ultimately whole engine performance is weaker. What is the point of building a turbo engine which has significant flaws at the beginning. That is basic stuff.
Tor Arne Kaasen
« Reply #11 on: July 24, 2007, 01:58:30 AM »
ose30 Yes i am trying to use it. but i bougt the m50 one and did a choppy.:D
Frankie . i have`t found any manifolds other than Fab666. (for the e36) :confused:
That`s why i am writing this thread. to find a good solution for a workeabl manifoild. Equal lengths i less important than smoot bends, separat tubs, right size tubs, material. but i am trying to fabbricat the most cost affective manifoild. SS tubs are not cheap for one 2,5" bend in norway 500nok 90usd.:eek:
This is crap, but it works to, not proformance.
This somthing i want to go for
Works god to
« Last Edit: July 24, 2007, 09:16:20 AM by Tor Arne Kaasen »
jiggaboo jones
« Reply #12 on: July 30, 2007, 10:47:33 PM »
damn i thought i was smart when i thought of that chopping 2 runners off the ebay manifold.   hows that goin?  that 666 manifold is nice but not my style, by that i mean im sure it cost 6x what it would to have a local shop make me a log
