Author Topic: Shaved the head What about tthe Block?  (Read 2345 times)
91318isfoundation
« on: July 18, 2007, 01:21:52 PM »
i shaved the head and putting new rings on pistons is there anything i shoudl do to the block so loong as i gots it in pieces? feed back woudl eb greatly appretiated
badboypolar
« Reply #1 on: July 18, 2007, 03:15:10 PM »
New bearings, All new seals {main, rear}.
Don't use any paper gaskets except for the intake manifold and oil pump. High temp silicone seal all that or you'll probably get a leak.
Also smooth EVERYTHING you can. Get a knife sharping stone (6"x3") cover the surface in oil and slowly and not much force, smooth everything.
Get the crank micro-polished.
Don't need to shave the block unless it's warped.
Since you shaved the head be sure you find a way to get the engine more fuel (injectors {Ford 5.0; I found some in a 96 t-bird} or FPR), or get a thicker head gasket.
When I did my engine, I replaced everything except the AFM, which of course now needs to be replaced.
Tor Arne Kaasen
« Reply #2 on: July 19, 2007, 07:26:09 AM »
Don't need to shave the block unless it's corrosion ore warped.
BMW E82 120d Coupe and BMW Z3 1,9 m44
