Author Topic: How to get oil to the turbo  (Read 4059 times)
Tor Arne Kaasen
« on: July 12, 2007, 03:06:27 AM »
Hi ther, nead to get oil from the engine to the turbo. can i use http://cgi.ebay.com/ebaymotors/BMW-Oil-Distribution-Block-Gauges-E36-M3-325-ODB-JTD_W0QQcmdZViewItemQQcategoryZ33676QQihZ020QQitemZ300128608757QQrdZ1
ore are ther other ways to get the oil.:confused:
BMW E82 120d Coupe and BMW Z3 1,9 m44
WeirdYo2
« Reply #1 on: July 15, 2007, 06:10:58 PM »
I just use brass fittings that you can get at almost any hardware store and tapped off the oil pressure sensor and have not had a problem yet.
ludiagsm
« Reply #2 on: July 15, 2007, 06:53:42 PM »
Quote from: Tor Arne Kaasen;29490
that will work , but you can also lessen Werdyio2 advise
why dont you contact with http://www.ticco.com or some of his friends in Norwey
« Last Edit: July 15, 2007, 06:57:26 PM by ludiagsm »
WeirdYo2
« Reply #3 on: July 18, 2007, 04:50:55 PM »
just make sure you get an orifice in to restrict the oil flow.
Tor Arne Kaasen
« Reply #4 on: July 19, 2007, 12:14:42 AM »
Quote from: WeirdYo2;29900
Do you mean restrictor,
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-OIL-021&Category_Code=GTBB
the Garrett GT seris has a restrictor biltdt in the char.
Is`t that ok with that one?:confused:
« Last Edit: July 19, 2007, 01:45:55 AM by Tor Arne Kaasen »
WeirdYo2
« Reply #5 on: July 21, 2007, 09:09:32 PM »
yeah, restrictor, same thing, just as long as you dont go dumping massive amounts of oil through the turbo or starving the turbo of oil you should be set.
