Author Topic: megasquirt questions  (Read 9388 times)
steve321
« Last Edit: April 26, 2011, 12:43:40 AM by steve321 »
« Reply #16 on: June 29, 2007, 01:25:41 PM »
Quote from: m44power;28777
im gone give you a motronic box for free then :p
Thanks for the offer, but I have a pile of parts of my very own!  It does not (or rather, cannot) need to get any bigger.
Personally I want to keep the car looking as stock as possible.  It is my DD and commuter car, so I want to keep everything stock except the motor electronics.
persianbmw
« Reply #17 on: January 09, 2011, 04:41:39 PM »
resurrection any updates on the diy did u guys ever get it done
« Reply #18 on: January 09, 2011, 06:26:22 PM »
I'd like to see that too, but three & 1/2 years later I'm doubting it'll get updated unless you do it.
Warsteiner
  • -Receive: 21
« Reply #19 on: January 09, 2011, 11:37:08 PM »
Due to the weather my project has been put on hold BUT I did have the car running on MSII V3 with no AFM on the stock motor. Ran just fine. The new project is a well thought out 2045cc motor with tons of goodies and utilizing either Alpha N or MAP or maybe even a blend of both. Not sure which will run the best but I will be testing all options.
I had talked to Mark D in the past and he did say that he could tune it on the stock ECU for the stroker motor but after re-thinking the cost of the Ostrich and then having to go back and forth and back and forth with tunes I decided to go the DIY route and am able to tune it myself with the help of a friend that has great knowledge on the MS units.
Here is a sneak peak...:cool:
http://s927.photobucket.com/albums/ad115/Warsteiner_photos/M42%20Stroker/
Cheers,
~Ralph
Damon in STL
« Reply #20 on: January 27, 2011, 12:45:00 PM »
I had my s14 in my race car up and running on MS II V3 Alpha-N and recently pulled it to replace it with an M42 turbo.  The plan is to get similar HP with a larger area under the torque curve.
I'm also doing something fairly unique with the tranny.....
Damon in STL
pdxmotorhead
« Reply #21 on: February 01, 2011, 11:35:56 PM »
I hope there is a very good scatter-shield inside that tunnel around  the flywheel!
I've had 2 blow over the years... Scary thing!
Dave
tamtom
« Reply #22 on: March 05, 2011, 05:18:43 PM »
hi has anyone done a megasquirt install on an e30 318is???
I want to kep the original wiring, i have built the ecu but stuck on getting it to work on the car. i am not getting a crank signal.
someone please help!!!!!!!!!!
tamtom
« Reply #23 on: March 05, 2011, 05:41:35 PM »
Quote from: Warsteiner;100278
Cheers,
~Ralph
