Author Topic: ECU / Car won't start after engine swap  (Read 2710 times)
teampump88
« on: June 16, 2007, 04:41:00 PM »
Whats up friends,
Just wondering, is the ECU from a 1991 E30 318i M42B18, the same as the ECU from the 1992 318iC vert? The 92 was an E30, not E36.
Having trouble starting after an engine swap with a known GOOD RUNNING M42B18 from a 92 vert.  It's cranking but won't stay on.
- Checked for spark
- Theres 48psi fuel pressure
- Firing order is correct 1 3 4 2
- Tried to spray Carb cleaner in the MAF, no go
Thanks!
teampump88
« Reply #1 on: June 16, 2007, 10:57:30 PM »
HEH... got it running... had the plugs from the harness reversed on the ignition coil...
:D
kowalski
  • El\' Duder
« Reply #2 on: June 17, 2007, 05:10:30 AM »
i had a similar problem when i did a swap as well. I was missing a power wire to something... can't remember what it was though.
Sale:
Fore Sale Thread
phredphish
« Reply #3 on: June 19, 2007, 10:26:42 AM »
Yeah, I had the same problem right after my swap. Took a bit to figure out that I had mis-wired from the coils.
