DISCUSSION
Engine + Driveline
Rotor thickness
Topic: Rotor thickness (Read 2411 times)
ABuseO
Jr. Member
Rotor thickness
June 14, 2007, 02:43:46 AM »
How thin can the rotors be before you cant turn them anymore?
Legendary
Rotor thickness
June 15, 2007, 04:28:47 PM »
Sorry, don't know the answer, but BMW rotors are made to be replaced rather than turned in order to reduce unsprung weight, and are also fairly cheap.
ABuseO
Jr. Member
Rotor thickness
June 16, 2007, 12:33:58 AM »
Such an answer suffices.
m44power
Rotor thickness
June 16, 2007, 05:54:51 AM »
minimum disk thickness : solid 10.7mm, ventilated 20mm, rear 8mm
DISCUSSION
Engine + Driveline
Rotor thickness
