Author Topic: Bigger brakes  (Read 4668 times)
ose30
Bigger brakes
« on: June 08, 2007, 01:18:51 AM »
Is there any brake caliper adapters available for these cars. I have some left over Porsche brake calipers i would like to use. If adapters are not available i can have them made, like i did for my Porsche
kowalski
  • El\' Duder
Bigger brakes
« Reply #1 on: June 08, 2007, 03:54:13 AM »
left over from what? and yes, you could have some brackets made if you so desired. only problem would be fitting them under your wheels assuming they are stock.
Sale:
Fore Sale Thread
ose30
Bigger brakes
« Reply #2 on: June 08, 2007, 04:09:48 AM »
Those yellow 6-piston calipers are from Porsche GT2. I have such a set going under my Porsche 944 Turbo. rear axle have Porsche GT3 rear calipers. Here a picture from which you can see also the adapters for front & rear calipers and also an adapter which brings handbrake shoes outwards a bit, so you can use GT3 rear rotor. These adapters were designed by my friend & I. My friend have a similar set up under his 944 Turbo.
Most likely i am going to use these calipers (996 carrera rear caliper) at front axle, because they just fit with inside original 15" wheel.
There is not necesserily any need for this upgrade, but i just have these calipers laying around, so why not use them ;)
Calipers which are in the first picture i posted are from left to right:
GT2 6-piston, GT3 4-piston, 993 4-piston (same as Audi RS2 had), GT2 6-piston, GT3 4-piston rear, GT3 4-piston. Those black small calipers are 944 Turbo front 4-piston calipers.
« Last Edit: June 08, 2007, 07:22:59 AM by ose30 »
thebaron666
ose30
Bigger brakes
« Reply #4 on: June 14, 2007, 03:47:03 PM »
I have use MBT adapters. They are good ones.
