Author Topic: low pitched rattling  (Read 2920 times)
manuel
« on: June 07, 2007, 03:10:18 AM »
Hi, when I start my car and during about the first 5 minutes of driving, I can hear a low pitched rattling noise from the engine, this noise dissapears completely after about 5 minutes driving, I suppose it is normal as the car has 130000kilometres, I assume it disappears once the engine gets to operating temperature, the noise is very slight. Is this normal?. Apart from that the car drives great, I will post some pics of it during this week
manuel
1990 Brillianttror 318IS
sheepdog
  • Site Admin
« Reply #1 on: June 07, 2007, 06:11:44 PM »
How old is your timing chain tensoner?
If it is over 40k miles or you do not know, change it. Also, check for anything in your lower pan.
Ramblin MAn
« Reply #2 on: June 07, 2007, 06:22:21 PM »
That sounds exactly like what I'm experiencing and posted in another thread. I'm ordering an m44 tensioner to replace it.
manuel
timing chain tensioner
« Reply #3 on: June 08, 2007, 03:08:23 AM »
I actually do not know if the timing chain tensioner was ever changed, I have owned my car for just 3 months, so it probably has not been changed ever, as I said the car has 130000kilometres on the clock, but the noise completely disappears after about 5 minutes, if as it seems changing the tensioner is a 10 minutes job, I might as well do it, I will check the oil pan in the next oil change as well, in about 5000k.
manuel
sheepdog
  • Site Admin
« Reply #4 on: June 08, 2007, 06:22:51 PM »
Quote from: manuel;27386
With that many miles, pop the tensioner before installing it. I do not recommend the 3500rpm and pray method especially on a tensioner of this age (or possible age).
manuel
tensioner
« Reply #5 on: June 11, 2007, 10:15:55 AM »
Sheepdog, do you mean that I should let the new tensioner expand, and then fit it?. Not sure if that is what you mean?.
manuel
sheepdog
  • Site Admin
« Reply #6 on: June 11, 2007, 01:13:54 PM »
Quote from: manuel;27556
Exactly.
It is not that difficult to do and is much safer for the engine.
