Author Topic: Oil Temp Fitting  (Read 6327 times)
rob_e30
Oil Temp Fitting
« on: June 06, 2007, 11:27:34 PM »
I found a great place for an oil temp sender when I was doing my rebuild and I though I would share.  It's on the oil filter housing and is the same size as the oil drain plug.  Check it out in the pic below.
vatos_p
Oil Temp Fitting
« Reply #1 on: June 07, 2007, 03:23:48 AM »
you can also make a hole to put the oil temp sensor to the oil filter cap...
steer with the rear !!!
e9nine
Oil Temp Fitting
« Reply #2 on: June 07, 2007, 07:23:08 AM »
That's where I pick up my oil temp signal as well for my cluster :cool:
kevo__
Oil Temp Fitting
« Reply #3 on: January 19, 2008, 10:15:27 AM »
hiya fellas i'm trying to put an oil temp sensor on mine and have been wondering where to put the sender, have you got any more pics or descriptions as i can't see the photo above for some reason?
cheers
Kevo
BrandC
Oil Temp Fitting
« Reply #4 on: January 19, 2008, 10:09:00 PM »
Quote from: rob_e30;27266
Rob, this picture does not show up. Where did you get your parts from? I am very interested in getting BOTH oil temperature and pressure. Thanks.
rob_e30
Oil Temp Fitting
« Reply #5 on: January 19, 2008, 10:33:14 PM »
I don't know why the image does not appear.  It won't let me upload it again, or a different one.  Perhaps there is a server error.  If you want a copy of the pic, PM me with your e-mail address and I'll send it over.
Rob.
kowalski
  • El\' Duder
Oil Temp Fitting
« Reply #6 on: January 21, 2008, 02:27:57 AM »
Quote from: rob_e30;41430
Rob.
uploaded for ya.
Sale:
Fore Sale Thread
nuvolarossa
Oil Temp Fitting
« Reply #7 on: January 21, 2008, 04:54:20 AM »
damn, I don't remember if drain plug is M26x1,5 or M12x1,5 thread
« Last Edit: January 21, 2008, 08:20:42 AM by nuvolarossa »
strypt
Oil Temp Fitting
« Reply #8 on: January 21, 2008, 07:37:20 AM »
It's M12x1.5
That port goes into the oil filter supply (pressurized) so it's no good for a return port. Better to weld an aluminium pipe in the oil pan so you don't have to use a pump.
nuvolarossa
Oil Temp Fitting
« Reply #9 on: January 21, 2008, 08:18:53 AM »
Quote from: strypt;41463
It's M12x1.5
thank you, I read bad and was thinking another thing:o
I'd weld the pipe in the pan for sure... :)
mach schnell
  • does it fast
Oil Temp Fitting
« Reply #10 on: January 31, 2009, 05:39:50 PM »
Excellent - very handy post!
Froos
Oil Temp Fitting
« Reply #11 on: January 31, 2009, 06:08:46 PM »
i would like some more info on that oil filter cap
rob_e30
Oil Temp Fitting
« Reply #12 on: January 31, 2009, 07:22:58 PM »
The guy that produced the cap is no longer in business.  BTW, we had a set of custom adapters made that allow you to use a standard 1/8" NPT sensor in either this fitting or the oil pressure sender fitting at the back of the oil filter housing.  We have a few extra if anyone is interested.
Froos
Oil Temp Fitting
« Reply #13 on: February 01, 2009, 07:49:46 PM »
can it be used for an oil cooler? ill be very interested if it can
rob_e30
Oil Temp Fitting
« Reply #14 on: February 01, 2009, 10:11:58 PM »
I don't think the fitting is big enough in diameter to work for an oil cooler.  This is for a 1/8" NPT sensor, and we use 3/8" NPT for our oil cooler.  It would work for oil supply to a turbo as well as oil temp or pressure.
